Results 1 to 25 of 25
Thread: easiest way to take off crank pulley bolt?
    ^The Bad Guy toonz's Avatar
    Lithia Springs LOL!!!!!!
    Default easiest way to take off crank pulley bolt?
    Yea without an air impact?
    Still here!
    Wheres the money?
    McDonough
    to many projects not enough money
    Columbus
    Quote Originally Posted by tank500999 View Post
    X2, i cant ever get them to come off with a impact gun.
    325is NJSC's Avatar
    Dec 2009
    Buford
    I've heard of people bumping the ignition with a wrench on it, but I've never had the guts to do it like that. You can also use a strap wrench which are like 5$ at advanced auto. Takes some grunting and sweat, but just use a breaker bar or something and you should be able to get her off.
    West palm beach
    1/2 in socket wrench, socket and a hammer....
    *NY Driver* CeOTiO8's Avatar
    In your girl
    Quote Originally Posted by NJSC View Post
    X2 that's what I do.... Just put it on with the rachet touching the ground then keep tapping the key
    PROUD SUPPORTER OF BAM-TECH WTF?
    Bunny Colvin's Hamsterdam
    In a worst-case scenario you can take the oil pan off and wedge a block of wood between one of the counterweights on the crank and the block to keep it from spinning.
    But putting a breaker bar on and tapping it with a hammer usually gets the job done. I wouldn't use a ratchet because you could strip the ratchet's gear out by beating on it. And a breaker bar is more solid and transfers the force of the hammer impact better. Don't forget to spray it with PB Blaster first, that will help too.
    ideal
    Quote Originally Posted by 99jdmLs View Post
    ive never got it off with an impact either other than a 3/4 impact.
    the bump thing is garage. a strap wrench from autozone isnt going to hold up. a snap on or any other 24" chain wrench it will work.
    Quote Originally Posted by Total_Blender View Post
    thats a lot of extra work.
    x2, I have one and its really important, also with re-torquing it back on.
    My line of work
    www.internationaljets.com
    lost 4 valves chriskm's Avatar
    Dec 2009
    Newnan, GA
    I've bumped mine off plenty of times. Just put a breaker bar and socket on the bolt, then wedge it in your suspension arm or something. Turn the ignition, and you'll hear it pop.
    I always think I broke something from the sound of it, but it never causes harm.
    Woodstock
    http://www.youtube.com/watch?v=RE-pzP8g_x4
    From the looks of it, it IS rocket science.
    PURP-a-trader PURP's Avatar
    this...
    DC5-R
    Gwinett
    I use my snap-on 3/8 cordless impact and it works every single time.
    I love my meds! antj101's Avatar
    ellenwood, Ga
    me and my brother just did this earlier tonight with his probe
    325is NJSC's Avatar
    Dec 2009
    Buford
    I've done it with a strap wrench from autozone, or maybe it was from O'Riley's
    Canton
    ignition bump works well.
    Try not. Do or Do not.
    Certified Gearhead SLR's Avatar
    Northeast Alabama
    My pulley had holes in it. Stuck two long bolts through with a nut... wedged a crowbar between the two bolts and turned the motor so the bar went into the ground. Then I went at it with extensions and a 6 foot bar.
    I need to get one of those specialty pieces up above. Always wanted/meant to get one.
    Quote Originally Posted by IntegraXTR View Post
    calling bs on that i have the newest 1 from snap on and out of the box on a full battery it wont do it.
    x2 on that fo show...
    toss a flathead in on the flywheel and breaker bar on the nut, bus that shittt off
    Jul 2009
    um..... i lock up the motor with oil and use a breaker bar.....
    just saying.....
    i tried the whole pin the cam...... well i ended up breaking the cam gear on a d16y8.....
    but i welded it back and it worked fine...
    but ive never had a problem locking the motor up.... taking a plug out and pouring a small amount of oil in it....then putting the plug back in..... turb by hand till it locks... then pop. break the pulley bolt
    Jul 2009
    ive also over torqued the pulley bolt.... and snapped it in the crank......
    turned out with a knife tho
    I would say, buy the $40 tool. It will save you a lot of bullshit time and effort. Just have to have a couple of breaker bars to use as well as a small extension and the correct socket. Works every time, even on h22's with their mongoloid crank bolts.
    My line of work
    GWINNETT IS GREAT!
    YEAA WE HAD TO DO THIS, IT WAS SOO FUCKING HARD WE GAVE UP
    we used close to 200 psi with the impact gun, that tool from the 2nd post and all kinds of shit..verrry tough we had to give up
    White 240 Jrh1992's Avatar
    Dec 2009
    There is usually a slot on the block behind the pulley for you to wedge something to keep it from moving.
    Oct 2008
    you can't go wrong with the crankshaft damper tool...it is what it's made for. The only purpose it have in life is to alleviate your ability to remove crank bolts. I got my from amazon and some of the sellers will get it to you in a day or 2
