Thread: d16z6 to b18b questions
    125hp of vtackness
    Apr 2009
    Kennesaw/Statesboro
    Default d16z6 to b18b questions
    I've been doin some reading on swapping my d16z6 to a b18b ls. My front crank seals been replaced multiple times by the previous owner and needs replacement again and it just has uber mileage. From my understanding as long as its an obd1 ls it should be plug in play. My question is will i run into a problem with the vtec wires not having anywhere to go on the ls motor? I plan on using a p06 nonvtec ecu. What additions or modifications to the 95 civic ex's wiring harness are necessary. Any help or suggestions are appreciated, just dont suggest a j32 type r swap or some crazy redonkulous stuff a college student who needs reliable transportation cant afford im on a budget.
    Wheres the money?
    McDonough
    dont worry about the vtec wire
    to many projects not enough money
    125hp of vtackness
    Apr 2009
    Kennesaw/Statesboro
    cool and also since im goin from one cam to two do i have to wire in a another cam position sensor? other than that all the other wiring should be the same
    the county
    if you're switch from a single cam to a dual cam...you are gonna need a transmission to go with the new motor. the d16z6 trans will not bolt to the b18.
    its gonna be a full swap....no just replace the motor and ride out. unless you do some modifications with a bracket to bolt the d-trans to the b-motor. probably gonna be best to just use a new harness with the motor as well.
    mounts may work...not completely positive about it.
    125hp of vtackness
    Apr 2009
    Kennesaw/Statesboro
    yeah sorry didnt make that clear i plan on doin trans ecu axles half shaft prolly new mounts, and though unecesary upgrading the brake booster and master cylinder and doing rear disks and manual rack just bc its stuff i have and been wanting to do. Mostly the stuff im confused about is wiring for example the addition of a cam sensor etc
    the county
    Quote Originally Posted by wahvtec View Post
    when you do the swap, get a LS harness that goes with the motor. it will eliminate all the problems for the wiring and shit since it just "plug and play"
    that is, if everything OBD-whatever you have, lol.
    125hp of vtackness
    Apr 2009
    Kennesaw/Statesboro
    yeah my cars obd1 similar to a lot of the ls's lol and will it hook right into that main connector at the strut tower? cus if so this swaps gonna be pretty much a breeze....as far as swaps are concerned
    1. use your harness
    2. Spend $50 and buy a p75 ecu.
    3. the mounts off your D will work minus the t bracket in the rear.
    This has to be the easiest swap into a civic other than another D so it will be really easy, you should be done with the pull and swap in a day easy.
    My line of work
    www.internationaljets.com
    Oct 2008
    vtec only works if you have vtec. It wouldn't hurt to keep the vtec plug hanging around just in case you find a jizzer head to swap out.
