Results 1 to 40 of 48
Thread: anti camber tires??
    fuck it thug it JdM_EJ2's Avatar
    the streets where we burn sweets,Gwinnett county hoe
    Default anti camber tires??
    ive heard that there is a tire that wont camber without having a camber kit. Is it true? i really dont know much about tires so appreciate any help
    Macon
    Quote Originally Posted by JdM_EJ2 View Post
    Do you mean that it won't get camber wear?
    yea there you go sorry wasnt really thinkin when i wrote this lol
    Macon
    No problem. I seriously doubt there are any, as camber wear results from an unaligned or improperly aligned suspension. I suppose that tires that wear slower in general, would, in turn, also show camber wear slower, but I suppose an expert would have to attest to that assumption.
    so if i get an alignment that would help the camber wear?cause mine are starting to camber pretty bad and i cant afford the camber kit for my car rite now so i wanted to know if there was a way getting around buying a camber kit or at least slowing the camber wear down
    Macon
    You need an alignment. It will fix the camber wear. A camber kit just allows you a greater control over your camber settings.
    Where Am I
    Doesn't Nitto have a camber tire????
    oh ok thanks alot
    Quote Originally Posted by Turbodude06 View Post
    yea that what i was told about Nitto
    Ridin' solo... n00bsrus's Avatar
    Augusta, GA
    shit if you find some anti-camber wearing tires let me know... hahaha my air ride is doing WORK to my tires.
    Drillin' switches on them bitches!
    Ridin' So Low...
    Where Am I
    ^Yea I could have sworn they had a tire made for cambered cars....
    Where Am I
    Google searched Nitto
    http://importtuner.automotive.com/62...res/index.html
    This explains it better
    http://www.hubcap-tire-wheel.com/nit...gen-tires.html
    I know my wifes civic had some Nitto Neo Gens on it, and they never wore uneven and it was slamed... And it handled
    realy good too....
    realy good too....
    yup thats what i had heard! thanks
    yes they are called nitto neo gens. they were made for cars that are slammed with bad camber.
    Macon
    Quote Originally Posted by blown_ss View Post
    Weird. I actually have those on my wheels right now.
    no accord
    alpharetta
    this still wear just not as bad as other tires. there will never be a such thing as a camber tire these are all marketing techniques so that people in the import scene buy more nitto tires. if you have neg camber the only way to fix it is with chamber plates. if your car is at a stock height then an alignment will get it back to spec however some cars have no chamber adjustment. most lowered cars have neg camber mostly in the front some in the back. my suggestion is get camber plates they last longer than tires, and cost less in the long run.
    Senior Member goi_ek's Avatar
    zone 3
    yea neo gens supposedly help
    Love Life
    Alpharetta
    An alignment won't help your camber wear, fyi. There are no factory camber adjustments on your Civic. You won't be able to correct negative camber without suspension modification or purchasing camber kits.
    As for Nitto Neo Gens, I suppose they slightly prolong the inevitable with a tougher shoulder material (many tire companies incorporate wear solutions), but there is no miracle tire that prevents camber wear.
    Quote Originally Posted by sina518 View Post
    this still wear just not as bad as other tires. there will never be a such thing as a chamber tire these are all marketing techniques so that people in the import scene buy more nitto tires. if you have neg chamber the only way to fix it is with chamber plates. if your car is at a stock height then an alignment will get it back to spec however some cars have no chamber adjustment. most lowered cars have neg chamber mostly in the front some in the back. my suggestion is get chamber plates they last longer than tires, and cost less in the long run.
    is this coming from someone that has used nitto neogens? i think not. they do work but will not fix the whole problem. i would still get a camber kit. since he needs tires then why not get something that is going to help him?
    rockin' the double M's
    l'ville,ga
    camber wear is a myth, its more about toe
    no accord
    alpharetta
    yea this is coming from someone who has owned neo gens. i had them on my bmw that was lowered on h and r race springs with bilstein shocks and they still wore down and were not that great of a tire i would have rather dropped 275 on chamber plates
    you do make a good point on the camber kit but he still needs new tires and i know that they work. they dont wear down as fast as other tires would.
    neo gens suck ass
    ATL DA SQUAD MEMBER #1
    HONDA_PARTS_CLEANUP_CLICK_ME
    no accord
    alpharetta
    if it wasnt a good point i wouldnt have suggested it, i understand he needs tires but he is better off buying some generals, or nexens and a camber kit, than buying some neo gens and 6 months down the road having to change tires again. if you look, were the tire would sit on the inside is alot wider than the outside thats why they claim better camber wear but still wears.
    Attached Thumbnails Attached Thumbnails -p6757986n1-jpg
    no accord
    alpharetta
    trust me i have had enough camber issues to know what the best options would be
    Attached Thumbnails Attached Thumbnails -n507462601_556519_1077-jpg   -n507462601_707103_7758-jpg
    l'ville,ga
    "set the toe and let it go"
    Love Life
    Alpharetta
    Quote Originally Posted by yerrow View Post
    There is such a thing as camber wear, same as toe. Do you believe those VIP stances won't wear tires if the vehicle is pointing straight?
    l'ville,ga
    do you think yuou're always driving on a perfectly straight and perfectly smooth road?
    yes camber angles play a roll, but the larger roll is played by toe angle
    this is true. my passenger front wheel has a toe and that tire always wears down faster than the other side.
    to the op, why dont you just raise your car back up, well if you have adjustable suspension.
    damn, i want that penis
    Love Life
    Alpharetta
    do you think you're always driving on a perfectly straight and perfectly smooth road?
    Of course not. I was referring to your implication that a toe and go will result in no tire wear, even if camber is 2 degrees or more negative. If I set the toe on a vehicle so that both fronts are straight, total toe is perfect, thrust angle is 0.00, etc., the tires will still wear on the shoulder.
    in da clouds
    there called nitto neogens they are made for camber
    my momma's house
    I had a set on my accord. I literally wore them down in about 3 months of daily driving around Gwinnett. Worst extra money I ever spent.
    Trend settin'
    Senior Member sprix!'s Avatar
    Camber. Not Chamber. Camber. I would agree with yerro here. Though camber wear is measurable and problematic, toe wear is probably more destructive and evident.
    G37s 6MT/coupe
    Mr. G-Spot S13_Chody's Avatar
    Nitto Neo Gens are the shit!
    Quote Originally Posted by marcos713 View Post
    got springs and dont like at stock height...
    ima just saave up for a camber kit sucks tho casue there like almost 5 bills for legit kits...im not a ebay type person
    thanks ia
    vanilla sky.
    $500 for a camber kit?
    cool
    Sep 2008
    Paulding/Cobb
    A lot of 8th gen civics have this problem, save for the camber kit. There are TSBs for a lot of the r18 civics because of the negative camber in the rear.
    No
    I've been running Neogens for a while. Yes, they do wear fairly fast. If you look, the only have a 280 treadwear rating. The only time I REALLY wore them down fast, was a weekend at the dragon with really shitty suspension.
    ....and my top let back umairejaz's Avatar
    Pakiland
    Damn, about time there was some truth to this tread.
    Learning everyday.
    Sounds like a bunch of people who don't have experience with alignments talking in this thread. Camber wear is very real. Yes, having your car toe in or toe out with cause tires to wear out more quickly, it is usually across the entire surface area of the tire. Camber will wear out the inside or outside more prominently depending on whether its negative or positive respectively.
    vanilla sky.
    last time i got alinement dude said the car was too low he couldnt get a wrench on it.in the end he said it could be done for $40dollars extra.true story,this place is strickly tire in stockbridge.
