Results 1 to 14 of 14
Thread: No Power smh Fuel problem?
    *NY Driver* CeOTiO8's Avatar
    In your girl
    Default No Power smh Fuel problem?
    Ok just started yesterday when I was on the highway, but I have no power what so ever. When I rev it takes long to build up(like it's missing or something) also I smell gas( A LOT) and I'm running out of gas fast now... I'm trying to explain it the best I can so please bear with me. I'm thinking it has something to do with fuel but I don't know where to start at... PLEASE give me some idea's to look at....
    My thoughts right now is that it's the fuel filter or fuel pump...
    Am I heading in the right direction? Please help cause I can't drive the car like this... Reps for all help and gift for somebody that can tell me what it is and it works
    PROUD SUPPORTER OF BAM-TECH WTF?
    your in limp mode. what cel do u have.
    In your girl
    I doubt that cause I put my stock ECU back in and it's still doing the same thing..
    check engine light? You may have jumped time, etc..
    In your girl
    Yea but it's always been on and never had a problem either...
    And how would that happen?
    well see what the cel is for, if its on there is a problem. Also jumping time happens.
    In your girl
    Ok cool... about to jump the ECU now and let you know what I got
    But in no way can it be the fuel filter?
    known as Charles
    Sounds like it could be the Map sensor. I guessing it's the DA in your sig. Map sensor has vac line running too it that may have come off.
    Main Stream Performance
    www.mainstreamperformance.com
    MSSracing.com
    In your girl
    Quote Originally Posted by Main Stream View Post
    Ok right now i'm checking fuel filter..
    Cause the car runs(idle) great it's just when I press the gas it acts up
    In your girl
    OK I just jump the ECU and I got a 4 and 6...
    This is a headache
    In your girl
    Correction: 6-Coolant Temp & 14 Electronic Air control.... Would that be the map sensor?
    2.2 CL
    Quote Originally Posted by CeOTiO8 View Post
    I would say map sensor... friend of mine had one that went bad. made car drive like crap, run rich and burn crazy amounts of gas...
    that would be my best guess also.
    Or dry rotted or cracked
