Results 1 to 33 of 33
Thread: Post your B series turbo setups
    Hamilton, GA
    Default Post your B series turbo setups
    Bout to finish up mine in a few months so I wanted to see what everyone else was doing around here.
    Post up you setup, pics, numbers, times whatever. I dunno if we already have a thread but oh well we'll have 2 if so.
    Mine will be
    Motor
    JDM B16A
    AEBS intake manifold
    UR lightweight flywheel
    B&M FPR
    Low compression pistons
    Turbo mods
    T3 turbo .60 compressor
    Spoolin performance log mani
    Tial 38mm wastgate
    Precision intercooler
    Greddy Type-S BOV
    Delphi 1000cc injectors(unless I can trade em)
    Electronics & misc.
    Hondata s300 and map sensor
    TurboXS dual stage boost controller
    Phearable.net obd0-obd1 conversion and dizzy jumper harness'.
    There's probably more but I can't think of it right now.
    I'm wanting to make around 350 wheel horsepower on 14-15 psi. I'll be running 10psi daily.
    What's everyone else working with?
    140 on one wheel
    columbus, ga
    Good thread! Shooting for 600-650whp untill i get a twin disc and the fuel setup and 10's for now then shooting for 9's
    BLOCK
    84MM 2.0 B18B1
    Manley Rods
    84MM 10:1 Arias pistons
    ACL Race Main bearings,Rod bearings and Thrust Washers
    Z10 Block Girdle
    ITR Oil pick up and windage tray
    Blue Printed and Balanced
    New OEM Crank Pulley
    ITR Oil Pump
    ITR Water Pump
    Toda Timing Belt
    Head
    USDM GSR Head
    Golden Eagle LS/VTEC KIT
    Skunk 2 Valve Springs
    Skunk 2 Retainers
    Blox Type B Cams
    Skunk 2 Cam Gears
    ITR Valves
    Omni Bronze Valve Guides
    Blox Cam Seal
    70mm BBK SSI Intake Manifold
    70mm Omni Power Throttle Body
    Hondata 4 Bar Map Sensor
    BDL Fuel Rail
    Precision 1000cc Injectors
    Custom Vented Valve Cover and Catch Can
    Trans
    SC1 USDM B16 Trans
    Carbon Coated Synchros
    Heat Treated Gear Set
    Phantom Grip Extreme LSD
    Turbo Setup
    Love Fab Top Mount
    Synapse 50mm Wastegate
    Precision Billet 6765 Turbo
    4 Inch Downpipe
    Go Autoworks 3 Inch Cold and 2.5 Hot I/C Piping
    Go Autoworks 900hp Intercooler
    Go Autoworks Couplers and Clamps
    HKS SSQV 2
    Hondata s300
    Hondata Boost Silenoid
    140 on one wheel
    columbus, ga
    jjspec,vtecace,spoolin,b18c1turboed,jjspec and all other sfwd's get your ass in here
    Hamilton, GA
    Lol. Callin all the B series. Keepin it old school.
    Jul 2009
    fully built turbo ls....
    230hp on 10psi....
    Privateer Racing!!
    Duluth,Ga
    I got some Gsr motor with a T25 turbo kit on it....
    aye bro .:Stirfry:.'s Avatar
    Quote Originally Posted by B18c1Turboed View Post
    lies. .
    ATL DAsquad Member #9
    Augusta Ga
    b17a1 on 5.62 lbs ... nothing fancy.
    93 sol Si
    95 sol S
    95 sol Si
    B-Town Crunk Force
    Statesboro, GA
    Quote Originally Posted by dallasb84 View Post
    230hp on 10psi....
    fully stock turbo ls...
    225hp on 10psi...
    Hamilton, GA
    Why are you people being so vague?
    Lol
    B-Town Crunk Force
    Statesboro, GA
    Quote Originally Posted by T2KU View Post
    Lol
    Laziness.lol
    Tail 38mm wg
    Blox cast iron mani
    Hallman mbc
    Garret t3/t4
    aem dryflow filter
    cca fmic
    hks ssqv
    dsm 450's
    walbro 255
    2.5 down pipe to fujitsubo exhaust
    tuned with Crome
    225 whp and 195 wtq I believe. On a 98 degree day.lol
    13.6 @103
    Internally stock from vc to oil pan.
    Hamilton, GA
    Quote Originally Posted by jdm>usdm View Post
    Laziness.lol
    Tail 38mm wg
    Blox cast iron mani
    Hallman mbc
    Garret t3/t4
    aem dryflow filter
    cca fmic
    hks ssqv
    dsm 450's
    walbro 255
    tuned with Crome
    13.6 @103
    OP, why are you going to run a XSpower boost controller if you have s300?
    Northwest Georgia
    Quote Originally Posted by -S Double C- View Post
    1999 Honda Civic CX Hatchback
    -Fuel and Management: Aeromotive XXXX Pump, 2000cc ID Injectors, Aermotive 1000 Regulator, AEM 5 Bar MAP, Hondata S300
    -Spark: MSD Digital 6 Ignition, MSD Coil, NGK Wires
    -Engine/Transmission-
    B18B/B18C1 Head (“LS/VTEC”)
    Golden Eagle HD Sleeves
    Manley H Beam Rods
    Arias Pistons
    ACL “Race” Bearings
    Ferrea SS Valves
    Super Tech Retainers
    Super Tech Valve Springs
    Skunk2 Pro1 Cams
    AEM Pro Cam Gears
    Edelbrock Intake Manifold
    Wavetrac LSD
    Liberty's Strait Cut Dog box Transmission
    Competition Clutch Twin Disc
    DSS 3.9 Axles
    Tilton Flow Control Valve
    -Forced Induction-
    Bullseye Power S372 Turbo
    Custom Top Mount Manifold
    x2 Tial 44mm Wastegates
    Tial BOV
    Spearco FMIC Core(Backdoor)
    4” Downpipe
    -Chassis-
    10 Point S&W Roll Cage
    Omni Drag Coilover Set
    Blox Rear Control Arms
    Kirkey Racing Pro Drag Seat
    Spinwerks Drag Wheels Front and Exospeed Rear Skinnies
    M&H Racemaster Drag Slicks
    Innovative 100% Solid Mounts
    ballin on a budget hondalover00's Avatar
    ga
    engine:
    chasebays cm1 harness
    b16a2 81.5mm
    golden eagle 1st gen sleeves
    eagle rods
    je 9:1 pistons
    acl bearings
    oem crank
    arp head studs
    arp mains
    arp rod bolts
    type r water pump
    type r oil pump with hamp gear
    oem head gasket
    oem belt tensioner
    oem timing belt
    b16 head
    3-angle valve job
    rocket valve springs
    rocket retainers
    oem valves and guides
    skunk2 intake mani
    omni power 70mm throttle body
    gm 3bar
    rc1000cc injectors
    aem fuel rail
    aem fuel reg.
    ngk plugs
    gsr obd2 dizzy
    ctr intake cam
    gsr exhaust cam
    gsr tranny
    kaaz lsd
    comp stage 5 clutch
    hasport mounts
    turbo setup:
    go-autoworks charge piping
    go-autoworks 6-point cage
    wal-bro 255
    nuekin ramhorn
    hondata boost controller
    apexi turbo timer
    38mm tial wastegate
    sc44 precision turbo
    3"downpipe
    greddy rs bov
    hondata s300
    v2 slicks and skinny setup
    blox drags
    Hamilton, GA
    Quote Originally Posted by josh green View Post
    Would there be no point? I got it for the freesky anyway.
    I mainly wanted it to be able to switch from low to high boost quickly.
    Privateer Racing!!
    Duluth,Ga
    I think with hondata you can put a toggle switch on it. Im more then a 100% sure.
    Privateer Racing!!
    Duluth,Ga
    Yup im right
    The S300 can control boost by using a duty cycle controlled output on OBD1 ECU pin A11 with a boost control solenoid to regulate air to the wastegate.
    Boost may be fixed, or varied by gear, with two settings which allow for wet/dry, pump/race gas or street tire/slicks settings to be selected with an external switch.
    140 on one wheel
    columbus, ga
    Quote Originally Posted by SPOOLIN View Post
    Manley H Beam Rods
    Arias Pistons
    ACL “Race” Bearings
    Ferrea SS Valves
    Skunk2 Pro1 Cams
    AEM Pro Cam Gears
    Wavetrac LSD
    DSS 3.9 Axles
    lol our long blocks are basically the same other then my cams are slightly less harsh on the valvetrain and im running oem valves BTW my whole turbosetup was changed today lol so updated parts list
    Northwest Georgia
    yeah but our clearances are nothing the same
    140 on one wheel
    columbus, ga
    lol whats your p2w clearances? i have no clue about mine golden eagle done the block and assembled it
    Northwest Georgia
    they aren't what golden eagle would set, clearance limits are one of the things i keep to myself. Mainly because ive blown up a lot of shit in the past to figure it all out.
    140 on one wheel
    columbus, ga
    so your basically saying your p2w clearances would possibly blow my shit if i ever used em on a build...lol Are you still running the street class this year or with the big dogs since you have an all out race car?
    revolution big mac's Avatar
    block:
    b18b1
    eagle rods
    ross racing 9:1 pistons
    ls crank
    kms block guard
    head:
    b16a=stock
    ls throttle body
    turbo kit:
    rev hard cast iron manifold
    tial 38mm wastegate
    garrett 52 trim turbo i think?
    2.5 open down pipe
    2.5 in turbo piping
    ebay intercooler
    rs blow off valve
    tuned on crome
    around 350 on 18 psi if i remeber correctly. will get correct numbers later
    F.A.N.A.T.I.C. primespark22's Avatar
    currently running 8lbs on my b20b at 257whp,plan is to take a day or 2 of work and slap the b16 head i got and making it in the 300's
    92 DA9 with a b20 on 8lbs daily
    DALLAS 8-4 1st in the nfc east
    Jul 2009
    225hp on 10psi...
    theres nothing stock about meh motor.......... but ok
    Southern Speed
    Macon
    he was talking about his own motor.....
    Southern Speed
    Macon
    Here is mine...
    Block:
    b18b1
    81.5mm darton sleeves
    eagle rods
    10:1 wiseco flat tops
    Head:
    b16
    supertech valvesprings and retainers
    ITR cams
    65mm Edelbrock TB
    Victor X intake manifold
    RC 1000cc injectors
    hondata IM gasket
    Turbo kit:
    MSPi Ram horn manifold(supposedly spoolins old one)
    Turbonetics 57 trim turbo
    Ebay Big ass intercooler
    Tial wastegate
    HKS bov
    3" downpipe
    MSD SCI ignition
    Last time around it made 393/274 on 15psi and 415/306 on 17psi both on pump gas, tried to go more boost but the ignition was messing up, so im going with an msd this time. On low boost and dr's it went 12.8@99 cracking a sleeve at the 1/8th mile. This time around im shooting for 450whp or max the turbo which ever comes first.
    where you at KP!
    d16_turbo
    Hamilton, GA
    Yea I knew about the boost solenoid for boost by gear but not the external toggle switch. I guess I'll just do that then once I get everything together.
    KILL jody754's Avatar
    silvercreek,ga
    Engine:
    B18b 83mm GE sleeved block
    arias pistons
    eagle rods
    B16 head
    Skunk2 valve springs and retainers
    supertech valves
    mild head work by steve cox of JGR
    skunk2 pro1's cams
    GE cam gears
    edlebrock manifold
    GE intake manifold gasket
    Omni 70mm throttle body
    ID 1000's injectors
    hondata S300 and map sensor
    MSD digital 6
    Tranny:
    B16 tranny w/quaife
    DSS 3.9 axles
    CC twin disc
    tilton flow control valve
    skunk2 pro S suspension hoping to switch to Strange as soon as i come up with the coin
    spoolins lenso's
    Turbo:
    S362
    SLS ramhorn manifold
    tial MVS wastgate
    tial Q bov
    Garret core intercooler 3" in and out
    B&R catch can setup like T1
    havent finished up yet about to paint car so will post numbers when finished
    www.MSSracing.com
    MAINSTREAM PERFORMANCE
    Hamilton, GA
    Sounds like it's gonna be sweet dude!
    SwiperNoSwiping!!
    hmmm, i havent thought of all of it yet, but heres one of my possibilities....
    Block:
    B18a1 bored to 1.9L or 2.0L
    iBeam rods
    (-blank-) forged pistons
    stock LS head, rebuilt,valve job...possibly a mild port job
    Crower 404 cams, just for fun..stock cams if 404's wont pass emissions
    550cc injectors
    tune on...cromePro?
    12 - 14psi High boost...6psi, daily driver.. T3/T4 turbocharger
    6puck clutch disc with stock pressure plate
    Im trying to see if i can have it make at least 300whp, or somewhere close to it on high-boost... Does it look possible?
    u remind me of a wigger !
