Results 1 to 10 of 10
Thread: Forza 3 Cockpit View Tweaking
    the land of race car ya-yas.
    Default Forza 3 Cockpit View Tweaking
    You're welcome:
    By adjusting the fov levels in the multiscreen setup (worked in FM2 aswell) you can move the cockpit view back to around GT5p view or even more!,
    as you can see default is crappy as you cant see the side mirror and only a part of the rear view mirror, 62 degrees is pretty much perfect and 90 is way too far (you can see end of arms), also the intro to race cam is further back
    62 degrees:
    How to do so under multiscreen setup:
    multiscreen on
    mode host
    channel 0 will do
    view center
    degrees hidden 0 or just play around with it
    degrees between screens 62 or whatever you want
    **goes to try this now.*
    No
    I did this a few days after release. Makes a HUUUGE difference.
    Quote Originally Posted by Sol-Badguy View Post
    Yeah, it worked for FM2 as well. I figured there would be some members on here who didn't know you could change the FOV.
    Athens/Memphis
    I knew you could because somebody on here posted about it, but kept forgetting to do it. I will definitely change it the next time I play.
    UGA: Everybody is laughing at us this year.
    Strictly Rotary Machado's Avatar
    Caracas, Venezuela
    way better!
    Southside Ridin HATCH
    Yup mine is set at 65 degrees.. Much better than Default
    Awesome, now if only the game had a look ahead feature.
    - IA Mgmt
    IA's Pedo-cord tdurr's Avatar
    Fayco
    sweet. ill be doing this tonight!
    Save ur engines!
    ALL CAPS JITB's Avatar
    i tried to tel people about this right after the game came out.. i guess u all missed it helps alot...
