Thread: 2 codes need to fix asap!!!!
    Default 2 codes need to fix asap!!!!
    Got a 98 honda accord lx 4cyl auto. The codes are P1706 and P1457. The P1706 says that lockup clutch does not engage probably cause open or short circuit condition in gear selection switch circuit. Poor electrical connection. Failed gear selection switch. WHERE IS THIS SWITCH LOCATED I GOOGLED AND IM RETARDED AND STILL CANT FIND IT!!! and the p1457 emission control system leak detected ( control canister system ) probably cause lose fuel cap. vapor canister saturated, failed vent solenoid, failed purge solenoid. WHERE IS THE VAPOR CANISTER VENT SOLENOID AND PURGE SOLENOID?!
    09 CTS - takin out the ladies
    08 Jeep Grand Cherokee - daily driver
    05 CBR1000RR Repsol - panty dropper
    vtakkk hondaxpurt's Avatar
    TALKING ROCK, GA
    the purge soleniod i think on those are on the back on the intake manifold somewhere, the vent valve i believe is on top of the gas tank, you have to drop the tank. try tightening gas cap and reset code. if it pops back on, you have an evap leak.
    98 Acura Integra LS-DD
    ??????????????????-project
    TALKING ROCK, GA
    and the gear selection switch i believe is under the console beside the gear shifter
    P1706 Means you will be needing to rebuild or replace your tranny.. Its a problem inside the tranny!!!
    P1457 Most causes is the gas cap check and see if a OEM honda is on there if not replace the gas cap with a OEM only!!!
    found the diagram for the tranny and yeah looks like its gunna need a rebuild or a swap. its the g/fs car so ill probably just get her a new one.
    if you wanna a new one they are around 1900 ish rebuilt new ones....
    If you wanna sale the car let me know
