Thread: help mee
    eg-gsr
    Sep 2009
    buford ga
    Default help mee
    hey a need a help i try to swap a gsr on my 2000 si i got everyting but i dont know wat kinda coversion harness i need it for the p72 ecu
    si-gsr
    Wheres the money?
    McDonough
    what year is the motor?
    to many projects not enough money
    SwiperNoSwiping!!
    which system does the P72 ecu run on, OBD1, or OBD2??
    That right there will determine which conversion harness you need, as your car is OBD2... The only next issue i could see you running into is whether its OBD2a or OBD2b. Just match whatever system the car's harness is, to whatever system the ecu is that you are wanting to run.
    I.E. OBD2a car harness ----> OBD1 ecu = purchase an OBD2a to OBD1 conversion harness.
    u remind me of a wigger !
    eg-gsr
    Sep 2009
    buford ga
    I not sure but I thinks is a 94 gsr n my civic is obd1
    si-gsr
    Banned STRteg's Avatar
    Oct 2008
    Somewhere in the USA
    Quote Originally Posted by papishulo View Post
    no your civic is obd2
    Jul 2009
    all you need is a 30 dollor ebay conversion harness..
    i got one and it works good...
    you need the obd2b to obd1 converter.....
    if you have a b16 in the civic it should all wire in just fine....
    aic will need rewire as well and youll need to wire in the butterfly valves
    eg-gsr
    Sep 2009
    buford ga
    ok guys so im going to get the obd2b to obd1 conveter
    n how i have to wire the aic n the butterfly valves
    si-gsr
    Quote Originally Posted by dallasb84 View Post
    x2 but i dont know about the ebay 1.
    eg-gsr
    Sep 2009
    buford ga
    no
    si-gsr
