Thread: tein basic coilover trouble, need pointers
    Killing it Since1982 bloodline's Avatar
    new york city
    Default tein basic coilover trouble, need pointers
    hey guys..well i just got some tein basics used with low milage. Im having trouble adjusting the top seat spring for the ride height adjustment, i got the bottom one loose and adjusted..i cant seem to get the top one to budge.
    The top seat spring is adjusted all the way to the top, the spring seems to be abit compressed, maybe causing difficulty for me to adjust the top seat spring?due to all the force? anyone have any suggestions? i used pb blaster ..didnt really budge.Should i just remove the top base mount? get the spring out? and then try to adjust it? i dont want the spring to kill me tho..i got a spring compressor but doesnt seem to work well at all on the teins.
    if anyone has any good suggestions id really apreciate it. repps to anyone that gives some good tips..thanks
    riding low is like a religion
    KINGZOFSOUTHTOWN
    Norcross
    well for the top one if its all the way at the top already, are you trying to adjust it back down or up ? if up your gonna adjust it back up your just gonan have to do with a spring compressor. and if down then you prob just have to work it until it wiggles down take off the top and then see if you can adjust it if not then your coils might be messed up. Easiest way to find out is just put the spring compressor on the springs, and take off the top so the springs wont come out at you. I have Tein SS's on my Teg and i dont have any problems, so could just be the adjuster or something. Just letting ya konw what i know hope it helps you out.
    -hmgdrfter-
    PP TRACK 350Z
    Norcross
    use a flat head and hit it with a hammer lol thats wat i do
    new york city
    Quote Originally Posted by HMGDRFTER View Post
    the top seat spring is all the way to the top, im trying to adjust it down for a lower height...do you recommend a certain type of spring compressor..the one that i have is shit..and i cant really to much adjusting at all..im gonna go at it again and see if i can get it to budge.. im gonna try the flat head and hammer method..thing it..its way hard to try to adjust something to stuff with out have the damn thing move or roll over aghh preciate the pointers tho..repps for ya bro
    423 KING
    Chattanooga, TN
    definatly try the flat head it should work
    18x9 +24 18x10+22
    KINGZOFSOUTHTOWN
    Norcross
    Quote Originally Posted by lanning View Post
    i did this with my ebay, but if my teins ever got stuck they cost to much to do that... maybe gently...
    -hmgdrfter-
    PP TRACK 350Z
    423 KING
    Chattanooga, TN
    lol put a rag over it
    18x9 +24 18x10+22
    PEENGONE Hektik's Avatar
    Like others said,flat head screw driver to loosen it up then use an oil filter wrench to get a hold of it. The oil filter wrench gives better leverage than the key. Make sure to clean the threads really good. All the dirt and grime get stuck in the threads and make it super hard to turn.
    new york city
    thanks for the tip fellas..the hammer and flat head did the trick..it was just hard to keep the thing from movin when i did it before..but it works..preciate the tips guys..repps to ya
