Seen a few write ups of this and decided to try it today.
What you will need: (Part numbers are from Summit Racing)
(1) pair Male -3 AN to Male 10mm x 1.0 Earls Brake Adapters EAR-592032ERL ($14.69)
(2) steel -3 AN swivel hose ends. Style is up to you.
I used 1 regular hose end - AER-FBM1100 ($5.25) &
1 45deg hose end - AER-FBM1110 ($10.25)
(1) -3 AN braided hose 10ft length. EAR-610003ERL ($29.95)
(NOTE) You probably wont need 10ft of the hose (I only used bout 4 or 5ft.) but Summit was sold out of 6ft so I just got the 10ft
(1) DOT 3 brake fluid - any qty/brand should work
THE INSTALL
Take a 10mm wrench and unscrew the fitting like so..
Install the new 10mm fittings. (NOTE: That notch of the block may get in your way a little but not so bad to where it wont screw in the threads. Just make sure you get it started good)
I then mapped out where I wanted to run the line. I wanted easy access to it so I just ran it over the top of the tranny back behind the T Bracket, behind all the hardline brakelines and over the brake booster.
I had a lot of excess hose so I tapped off where I wanted to cut it and used a punch and hammer to cut it like so..
Install the braided hose to the hose ends. Check this link for install instructions.
Then just run the line where you want it and hook up the hose ends and VOILA!
(NOTE: Remember to bleed you clutch )
