Results 1 to 16 of 16
Thread: Lighterfaster Sunroof Plug/Rear Diffuser
    Apr 2009
    Default Lighterfaster Sunroof Plug/Rear Diffuser
    ***See All Available Sunroof Caps/Diffuser***
    Put your car on a diet today and install one of our race proven sunroof plug kit (SPK's) today. We didn't invent the sunroof plug, we just perfected it. There is no other single body part you can replace that will give you the same weight reduction benefit as an SPK! Our kit shaves lots of weight UP HIGH! If you care about any of the following bullet items you need one of our kits!
Benefits:
· Reduce Vehicle Weight
· Lowers Vehicle Center of Gravity
· Reduce Weight Transfer
· Lower 60 ft and/or Lap Times
    Our kits include:
· Vacuum infused carbon fiber panel
· Steel or aluminum mounting brackets depending on model
· Black, countersunk, stainless steel mounting screws
· Black, countersunk, stainless steel nylock nuts
· Bracket locating tool (to ensure flush mounting panel)
· Special Aluminum drive rivets where applicable
· Black silicone to seal the panel (special technique included)
· Comprehensive Instructions and bracket locating diagram
    Whether you drive your car to and from work or only drive a quarter mile at a time you will see remarkable benefits with our new diffuser design. At speed a rear bumper cover can increase overall aero drag and promote lift. Neither of these effects are desirable on any vehicle, and as speed increases the problem becomes more pronounced. Think of your rear bumper as a big air brake. Our diffuser removes the trapped air and lets it flow freely through the bumper cover. Our product promotes higher track speed and gives the driver more stability at those high speeds.
This product has been tested at the drag strip on a 9 second, 150mph drag Civic. Each diffuser is CNC water jet cut, and features a glossy finish. It measures approximately 4"x45", and comes with easy to read instructions for trouble free install and black painted rivets. For those really fast racers out there you will be happy to know we machined a center hole just for your parachute tube. A secondary benefit for some cars using parachutes is faster parachute deployment due to the larger volume of air exiting out the bumper cover.
    Shipping is always included in the price you see inside the 48 lower United States.
    www.CorSportUSA.com
    Aftermarket Performance Defined.
    Check out VSpeedUSA.com for your domestic vehicles!
    Apr 2009
    www.CorSportUSA.com
    Apr 2009
    Built to order, shipping always included in the price!
    www.CorSportUSA.com
    ^^this guy loves you jdm-civic's Avatar
    the sky
    question:with these kits, will it render the sunroof useless as far as opening and closing?
    Emancipate yourself from mental slavery, non but ourselves can free our minds- Bob Marley
    facebook me: http://www.facebook.com/profile.php?id=779918877
    Apr 2009
    ^ Yes, you weld in brackets and bolt in the piece. You could unbolt it if you wanted to open it, but other than that you won't be using the sunroof much. lol.
    www.CorSportUSA.com
    the sky
    oh ok.i think it would be cool if it was a peice to just reppace the glass so it could still slide open and closed! but i checked the site and its good stuff!
    Apr 2009
    Ya, it drops a decent amount of weight by getting rid of the unnecessary parts (motor, glass etc). Definitely not for anyone light at heart, and afraid of a ltitle welding.
    www.CorSportUSA.com
    Apr 2009
    Made to order!
    www.CorSportUSA.com
    Apr 2009
    www.CorSportUSA.com
    Apr 2009
    Lighterfaster weight savings!
    www.CorSportUSA.com
    Apr 2009
    Made to order!
    www.CorSportUSA.com
    Apr 2009
    Lower your center of gravity!
    www.CorSportUSA.com
    Apr 2009
    Made to order.
    www.CorSportUSA.com
    Apr 2009
    www.CorSportUSA.com
    Apr 2009
    Lighterfaster!
    www.CorSportUSA.com
    Apr 2009
    Made to order!
    www.CorSportUSA.com
