Results 1 to 14 of 14
Thread: Over Heating/ No heat/ really hard cold starts
    2.2 CL
    Default Over Heating/ No heat/ really hard cold starts
    go to crank my car this morning and it starts moaning groaning etc... after 10 min of cranking it finally turns over. so i get in it to take off for work and i notice the temp. gauge is a little higher then normal. So I keep an eye on it and it starts creeping really high( not to the red zone but darn close) during this whole process my heat is ICE COLD and my resovoir bucket is spewing out fluid. Im thinkin a thermostat thats stuck closed. any opinions before i waste the money???
    barrow county
    have you try and see if there is anti-freeze in the radiator? how much do you drive this car? your dd?
    2.2 CL
    Quote Originally Posted by blue_gt View Post
    its full.. everyday
    eg6
    Apr 2009
    my cousin's has the same prob haven't figured it out but im guessin it might be the thermostat.
    IS300 NEMO's Avatar
    We Fuckin...
    are you running anti-freeze or water?
    YOURMOM tnomud's Avatar
    Coweta
    could be frozen.......... cold weather+no heat+overheating = freeze.
    2.2 CL
    Quote Originally Posted by NEMO View Post
    antifreeze... and im currently draining to put a new tstat.
    Alpharetta, Ga
    sounds like a serious headgasket to me. you cranking it for 10 mins was you getting the coolant out of the cylinders enough to start it. and the over heating and the overflow spilling out was combustion gases going directly into the coolant system.
    head gasket or cranked block or head.
    The G Spot Hero
    Alpharetta, Ga
    Quote Originally Posted by SLo_MKIII View Post
    t-stat is not going to make you crank over for 10 mins to get it to start.
    The G Spot Hero
    General Tech Hater
    Quote Originally Posted by DirtyMechanic View Post
    x2.
    2.2 CL
    Radiator has a small leak and It needed new coolant. problem fixed thanks guys
    Alpharetta, Ga
    if you ever have coolant temps issues... always always look for leaks first... thats the number one reason a lot of issues stem from. low coolant. then start looking at other easy fixes that are most likely. t-stats depending on the car are fairly reliable. and replacing one for fun. or you think is the problem is no the best way to go about fixing somehting, even if something indicates that it might be a t-stat... its called di-ag.....
    The G Spot Hero
    vanilla sky.
    i had overheating issues today also/
    Southern Belle
    Jan 2010
    Mtown
    definitely sounds like your thermostat is sticking
