Results 1 to 40 of 61
Thread: ok i changed my mind im gonna do it
    Certified Gearhead cprtyler's Avatar
    cedar town
    Default ok i changed my mind im gonna do it
    ok guys give me input i already have a na b series and in process of turbo lsv. i feel like im steping back but i was told by a friend to give a try so i am. heres what my plans are.
    a6 block bored 20 over
    p29 pistons
    eagle rods
    crank micro polished to 10k
    y8 head
    ported polished and 3 angle valve job
    crower valve train
    stage 3 cam
    toda cam gear
    p28 chipped with chrome
    330cc injectors
    skunk 2 intakemani
    obx 60mm tb
    hondata tb/im gasket
    bisi or tri y header
    skunk2 fuel rail and fpr
    msd dizzy
    nology wires
    pulse star plugs
    light weight pullys
    93 del sol tranny
    with light weight flywheel
    stage 2/3 clutch
    aftermarket lsd
    i figure about 160/180hp area is this realistic? no negitive comments just some advice on what u think
    cb7 sold
    eg8 shell
    eg1 traded
    ej1 mini me sold
    Del sol w/h22 all motor
    Del sol w/ls swap sold
    Dc2 Itr ft w/B20v dd
    West palm beach
    it will be fun, thats for sure...G/L
    NO ADVERTISING
    -IA MANAGEMENT
    cedar town
    ya i think so i doubt its a dd lol
    cb7 sold
    eg8 shell
    eg1 traded
    ej1 mini me sold
    a lot of money for about 150 wheel. Its not gonna be worth it my man.
    My line of work
    www.internationaljets.com
    cedar town
    thats just a guess on hp i have block and tranny rods crank pistons and few other things already just waitin to be assembled i may have 100 bucks tied up in it all, i figure cams abd headers is where ill spend most money though. but i think i underestamated on power will c lol thanks though
    cb7 sold
    eg8 shell
    eg1 traded
    ej1 mini me sold
    have you looked at a lot of all motor d graphs? not really big power. Like bolt on gsr power on a fully built one.
    My line of work
    cedar town
    i know its not a gsr but like punkr6 said it will b fun iv seen all kind of numbers and graphs on d's anywhere from 130-230 na'd i just want to build a d before i sell the b's and d to go hseries you know i know some stuff is pricy thats fine, i know numbers may be more or less but its just for fun i was dared to build it on my specs to c what i could get and we have alil cash on it so mainly for fun ya know, who knows might get a crx and drag it if the comp. and numbers sre good for ME. throw me numbers u woukd expect to c
    cb7 sold
    eg8 shell
    eg1 traded
    ej1 mini me sold
    145-150 wheel hp/ 120 wheel torque. Who's gonna build it?
    My line of work
    Out the game again!!
    southside of the border
    p29 pistons
    eagle rods (STOCK RODS ARE JUST FINE FOR N/A)
    y8 head
    crower valve train
    stage 3 cam
    toda cam gear
    330cc injectors( YOU WONT MAKE ENOUGH TO COMPENSATE FOR THE EXTRA FUEL SO STOCK 240CC ARE GOOD)
    skunk 2 intakemani
    obx 60mm tb( STOCK IS GOOD DONT WASTE UR MONEY)
    bisi or tri y header( bISI IS THE SHIT JUST SAYIN)
    skunk2 fuel rail and fpr( STOCK FUEL RAIL IS GOOD FOR UP TO 400HP NO NEED FOR BIGGER ONE)
    msd dizzy( DONT NEED tHIS EITHER)
    nology wires
    pulse star plugs
    light weight pullys( YOU MUST PLAN ON CHANGING YOUR BEARINGS SOON)
    93 del sol tranny
    stage 2/3 clutch
    aftermarket lsd
    Fixed with all that said you dont really have to many power adders save most of your money for tuning and ill say you could reach 160whp but who knows i have a n/a d im not shooting high at all should run pretty decent though
    Soon!!
    cedar town
    the motor is going to be completely redone me and a buddy of mine are rebuilding it (he himself has a turbod d thats close to 350) everything going to be vated, and everything. allmotorx what else u suggest as power adders
    cb7 sold
    eg8 shell
    eg1 traded
    ej1 mini me sold
    Apr 2009
    Villa Rica
    Well, I've seen a few d series builds & heard of a few d series builds that can run from 170hp to about 240hp for a total cost of $1500.... It's a long shot in most builders minds that a d series can't lay this much power down as a na build but like I said I have seen it done & read from other forums, so it's defiantley not a wast of time, but I'm sure according to other builders (which names won't be said) from this forum it would be.... I say go for it because I'm going to build mine basically the same way but the only difference is I will be boosted & shooting for around 360hp as close as I can to 300 ft lb torque but the trq is a long shot....
    Reps for (cprtyler) on finally coming around to wanting to play with a d series....
    Your headed in the right direction already basically a good ported head increase the displacement a lil .40over bore basically 76mm. Aggressive cam with good amount of compression, also you could go with a dc sport header if you dont want to wait 2weeks for bisi header or if money is an issue and just modify the collector on it and the basic bolt ons could put you anywhere from 135-160whp with a good tune
    Soon!!
    and a far as bottom end use stock rods with arp rods bolts and your good to go
    Soon!!
    240 hp please, even crank that is pushing it.
    My line of work
    No go del slo Jdmsol's Avatar
    Nov 2009
    Bremen
    Its possible I was goin to do it but went b instead and decided to hand it off to a loving home lol good luck bro and well c what happens when its done.... Your old sol against what ever u put the d in!!!!! lololol
    JDM as......
    93 accord cb7
    (traded)
    93 del sol eg1 (traded)
    94 integra dc4 (sold)
    96 db7 ls-t (daily)
    cedar town
    so .40 over instead of .20 huh ok i really looking to build the piss outa this so thanks on cam go bigger then a stage 3? and ya mr ex finally lol i said never but im eating that lol
    cb7 sold
    eg8 shell
    eg1 traded
    ej1 mini me sold
    cedar town
    na ill leave that for the 4door lol jdmsol, i have dudes buil on that 240hp na but way to pricy lol id like 200 if any suggestions lol
    cb7 sold
    eg8 shell
    eg1 traded
    ej1 mini me sold
    It all depends on your goal bigger isnt always better just look at a few cam specs and see which one would be suitable for you
    Soon!!
    I had an all motor D once, my first build I did. All the good stuff. HATED it for the money, but everyone has to learn. Or maybe budgets are set, money is tight, if so then disregard my other statements. turbo that shit, I've built turbo engine's for people as well, that would be the ONLY D i would have ever again.
    My line of work
    Apr 2009
    Villa Rica
    Quote Originally Posted by Starrfire View Post
    If it's done right & the budget can expand, nothing is impossible.... I say just shoot for 200hp.... There's alot of other forums like civic-eg.com that have alot of na'd & boosted builds.... The highest amount of hp for a boosted d series that I've seen & perform was I believe 416hp.... But there are other boosted d series with way more power, just saying it what I've seen.... So like I said to go na and want to shoot for 200hp isn't a long shot at all.... It just depends on your budget & what items you choose to run with....
    But everyone has their agreements & disagreements about it.... I say run for 200hp just because it would be an insane build & blow alot of Honda owners minds when you could possibly run a low 12 in 1/4 mile pass on a d series build with street tires, maybe lower if you run with drag radials.....
    cedar town
    i have a budget yes may go over alil lol i m building a boosted lsv i just wanna try and c what kind of power i can get 190 or so would be great not going to b dd but for fun on weekends at track im looking for best cam to suit my clearances on the p29 pistons
    cb7 sold
    eg8 shell
    eg1 traded
    ej1 mini me sold
    Apr 2009
    Villa Rica
    Point well made....
    Apr 2009
    Villa Rica
    Damn thread is growing quickly....
    West palm beach
    everyone should look at this before making judgments, very little mods and right at 130 whp. Not to bad for the $$$$
    Y7 with D15B head IHE
    NO ADVERTISING
    -IA MANAGEMENT
    cedar town
    190-200 new goal lol
    cb7 sold
    eg8 shell
    eg1 traded
    ej1 mini me sold
    Not bad at all makes me wonder wht ill make
    Soon!!
    cedar town
    me too im really interested
    cb7 sold
    eg8 shell
    eg1 traded
    ej1 mini me sold
    Apr 2009
    Villa Rica
    Quote Originally Posted by allmotorX View Post
    x2
    cedar town
    im going to c if i can find build sgeet for that motor my friend in fl built
    cb7 sold
    eg8 shell
    eg1 traded
    ej1 mini me sold
    Post up once you do^^
    Soon!!
    cedar town
    ^^^ ok i got to find it in school crap lol
    cb7 sold
    eg8 shell
    eg1 traded
    ej1 mini me sold
    cedar town
    ok so iv done 2 diff compression calculators with z6 block and y8 head plus p29 pistons compression is going to be about 14:1 so e85 or 110 octain will be my friend does this sound right
    cb7 sold
    eg8 shell
    eg1 traded
    ej1 mini me sold
    I'm seeing 12.64:1 on a stock bore on zealautowerks.com
    My line of work
    cedar town
    sorry lol 2 layer headgaskt and 40 over
    cb7 sold
    eg8 shell
    eg1 traded
    ej1 mini me sold
    Eh the taking out of the middle layer of metal would be a little too much trouble, and .40 over may be a little much, but it may be safe.
    My line of work
    cedar town
    so u suggest oem headgasket, ok. what do u think about itbs for a all race application cuz thats what i think im planning on doing strictly drag
    cb7 sold
    eg8 shell
    eg1 traded
    ej1 mini me sold
    big money for little power, just do a good intake manifold.
    My line of work
    cedar town
    ^^^^^ok check intake mani, i checked out that web site what feet did u put for atmosphere, whats a good valve train to prevent valve float at high rpms i want to spin at least 8500 or alil more. (im not asking u to look up parts i just know u said u built one pretty sure u know)
    cb7 sold
    eg8 shell
    eg1 traded
    ej1 mini me sold
    Supertech will be cheap but still good. But still gonna run about $600. Valves, and springs and retainers though.
    My line of work
    cedar town
    ok supertech, what do u think bout ferria or crower, like i said building a race motor now so got to be highh revvin lol. any suggestions on a cam? dont really like bisi cam
    cb7 sold
    eg8 shell
    eg1 traded
    ej1 mini me sold
