Results 1 to 24 of 24
Thread: DA overheating need help asap!!
    Certified Gearhead 4drlschick's Avatar
    Oct 2008
    Rome
    Exclamation DA overheating need help asap!!
    Ok here goes. I didn't see this problem in the forum already but if it is im sorry for reposting. I have a 1992 da rs model. About a month ago we replaced the thermostat when it had started overheating some. The thermostat lasted for about a month then we ran across the same problem again so in thinking it was the same problem replaced it all over again with another 180 degree thermostat. Well to my suprise this didn't help at all it actually made it much worse putting the car almost into the red very quickly. I have a job that i work every night where im required to drive approximately 200 miles a night and so it was very hard for me to just stop when the car was overheating but in fear of blowing the head gasket or worse I left work and parked my car at home. Here is a run down of how it was overheating. When I would come to a stop it would stay normal then when I accelerated it would rise up a good bit. Also sitting still the heat would feel like air conditioning and then get hot again at acceleration. In fear of messing up the car bad we took out the thermostat and I drove it like this for a night. The car then ran almost on cold idle all night long. It would barely warm up when it sat still for about 10 mins but then would drop back way below cold again when I accelerated. I have no heat also of course when we did this. In fear now of hurting the motor due to running the car with it this cold I went and bought another thermostat this time 170 degree since HONDA calls for a 172 degree thermostat to work properly. The car is not overheating just yet but it is starting out the same way as before by the heat feeling ice cold while sitting still idling and then getting semi warm after acceleration. The temp hand is right at half way which is not a normal for this car either before the temperature problems it would sit between a quarter and half way as the normal for idle. Im beyond confused on what it could be and being limited on funds isnt helping either. Please if anyone knows what it could be your suggestions or advice is greatly appreciated!!!
    95 eg sedan with complete ls swap tons of extras.... SOLD
    88 prelude si lowered like a mother.... TOTALLED
    95 prelude si jdm f22b swap.... TOTALLED
    03 celica gts toooo much money in this one..... SOLD
    92 da teg NEW DD
    89 ef hatch.... SOLD
    95 ex/si coupe (this bitch is clean as fawk)... awaiting swap... NEW hopeful DD
    Sounds like a bad waterpump to me
    NO ADVERTISING
    when was the last water pump change. did yall bleed all the air out of the system after changing the stats.
    General Tech Hater
    x2. Sounds like air in the system. Where do you keep getting these non-honda thermostats?
    PEENGONE Hektik's Avatar
    Quote Originally Posted by envision View Post
    same thing i was thinking
    Oct 2008
    Rome
    Quote Originally Posted by MidLifeCrisis View Post
    advance auto parts.
    we did bleed it tonight i made sure to use the bleeder valve and completely emptied the radiator to make sure to get all the air out.
    there was alot of stuff in the new coolant though thats the only reason i was thinking it was the radiator.
    92 da teg NEW DD
    GWINNETT IS GREAT!
    headgasket/waterpump
    replace it
    Senior Member PD code 805D's Avatar
    black hollywood ga
    sounds like a clogged radiator. You probly cleaned it when you did it the 3rd time. I would suggest flushing it over and over with water then drain and fill when it is finally clean water coming out.
    need CA$H? I WILL BUY YOUR STUFF OF VALUE.... PM ME WHATCHA GOT!
    *NY Driver* CeOTiO8's Avatar
    In your girl
    I got a BRAND NEW water pump for your car if you want it... (name your price)
    PROUD SUPPORTER OF BAM-TECH WTF?
    Quote Originally Posted by 4drlschick View Post
    what color was said stuff. like little black flakes.
    Oct 2008
    Rome
    replace it
    headgasket is fine. already checked it.
    water pump im not completely sure about.
    Quote Originally Posted by PD code 805D View Post
    thats what im thinking to be honest the little fins on the top of the radiator have white crust stuff all over them kinda closing them up. we cleaned it did a radiator flush but im thinking the radiator is just tooooo far gone. im ordering one in the morning. hopefully that will fix the problem.
    Quote Originally Posted by CeOTiO8 View Post
    ill let you know man. i know advanced sells them for 38 brand new. im still unsure if thats the problem.
    yes and it was pretty murky only after being in there a day also.
    92 da teg NEW DD
    get a new radiator. call summit and theyll overnight one to you...
    did you do a pressure test. how do you know the headgasket is good.
    Quote Originally Posted by Hektik View Post
    Check the headgasket if you had your system completely flushed and the coolant is still dirty you may have another problem.
    NO ADVERTISING
    college park
    stop buying advance auto thermostats!!!! trust me ive been down this road before the price difference between autozone,advance,oreily, is minimal from oem dealership from honda i crapped out 3 advance thermostats then went to honda paid a extra 6 bucks and never had a issue
    now with LSD
    i doubt the system was cleaned properly. i can put money on it the most that was done was a garden hose in the rad.
    I agree I thought that maybe they had it done right but you never know
    NO ADVERTISING
    i wish i could see IA threw a noobs eyes again. you will learn fast around here just because its was done or said to be done doesnt mean it was done or done correct.
    Oct 2008
    Rome
    yes we did. im ordering a radiator today hopefully it will fix the problem. ive had the headgasket checked its not it.
    Quote Originally Posted by JDMJAYDC2 View Post
    ill get one later this week after i get my check.
    guys i know im a girl but i know a little bit about cars. no it was not done with a garden hose. granted it was done using a radiator flush from the parts store it may have not been the greatest choice i dont know but i followed directions completely and to be honest there is no more flakes and such coming out of the coolant but the top of the radiator still has the white nasty stuff i guess from buildup around the fins. im hoping when i order the radiator today it will solve my problem.
    92 da teg NEW DD
    Oct 2008
    Rome
    and yes we made sure to use the bleeder valve and do it positively right this time. ill get a different thermostat later this week also seeing as to my pay check went to other parts this week.
    92 da teg NEW DD
    college park
    pm'd
    now with LSD
    Sounds more like a water pump issue. I have newish radiator from a '92 Integra if you want it. pm'd
    Oct 2008
    Rome
    replaced water pump and radiator still wanting to warm up past half way but not as serious of an overheating issue as before. after sinking as much money as i have in the past two weeks im lost as to what to do.
    92 da teg NEW DD
    Is your fan coming on.
    Oct 2008
    Rome
    yes its working. that was the first thing we checked. im about out of ideas to be honest.
    92 da teg NEW DD
