Thread: battery dieing
    griffin
    Default battery dieing
    i have a little odyssey battery. i can just leave my door open and go in the store for a short min and it well not crank the car wen i get back and one time i was going down the road had the lights on ,heat, wipers,and sliped on the ctuch and the car would not start had the battery cheacked and the batterys good. but everyone telling me to get a bigger battery
    Check your grounds... Even though they look ok they may not be... Its pretty easy to check the charging system. I would check the alt. voltage, all the grounds and battery terminals... How many cold cranking amps is the battery?
    Warner robins ,Ga
    Quote Originally Posted by TommyD1919 View Post
    as said check grounds i have had many problems with those they get bad corrosion sometimes. check alt and fuses if all that fails try a new battery you can always return also make sure your trunk light isnt staying on or etc. like amp wires touching the hot wire going to the batt. etc
    griffin
    griffin
    thinks i well do all the checking tomorrow
    Metro ATL
    Check the alternator if the battery is good.
    Mr. Azzhole BUGMAN's Avatar
    Trailer Park
    I have had many batteries checked GOOD by AZ and AAP when indeed they were bad or had dead cells.
    Also always check your alternator when having any type of battery issue.
    Hope this helps.
    KINGZOFSOUTHTOWN
    Norcross
    Quote Originally Posted by Gold'n S14 View Post
    x2 i use to have this problem on my civic, battery always tested good, but my alternator was bad so battery wasn't recharging... and yes check your grounds.
    -hmgdrfter-
    PP TRACK 350Z
    Athens
    X2 on what Buggymayne said.
    2013 Dart 1.4T 6MT
    boooooostin'
    I was having the same issue with my Odessey I had to dump it!!! I got a kinetic battery it's a very good battery if you look you can get them cheap on ebay from a company in New York.
    NO ADVERTISING
    try 1 with atleast 410 cca
    griffin
    i think am going to move the batt to the hatch with a kit from summit wen i get the money for the kit and a batt.dont wont to be stuck on the road or at the pump again
