Thread: Electrical/battery/starter/dizzy
    ѦʈʃѦŋʈѦ
    Default Electrical/battery/starter/dizzy
    Alright, I have a 94 GSR with a LS motor, car started up fine, and it just shut off. I tried jumping it, it won't. Dash lights/no power DO NOT work. It'll turn over though. What can it be?
    Apr 2009
    Villa Rica
    Maybe a Rotor Button inside Distributer Cap or ECU is bad.... Sounds like what happend to my buddys eg8.... We went through everything & then I told myself to check the ECU.... Went to a junkyard, pulled one & put it in & the car fired right up....
    ѦʈʃѦŋʈѦ
    ^i'll check that...
    Warner robins ,Ga
    check all fuses
    Columbus
    check and see if your getting any spark....if could be a fuse also. if it is a fuse, then it blew for a reason. you have to figure out why or it will just keep blowing.
    Quote Originally Posted by xdavidscenex View Post
    check all fuses
    +1
    NO ADVERTISING
    fuse or major electrical.
    ѦʈʃѦŋʈѦ
    It was a loose wire.
