Results 1 to 19 of 19
Thread: Car still won't idle.
    Duluth, GA
    Default Car still won't idle.
    I replaced my IACV already to try to fix the problem. And re-wired it straight to the ECU. The car turns off immediately after you put foot on clutch or take out of gear. It drives fine if you're in gear and doesn't bog out. I am at a loss here. Just sick of tapping the gas at red lights to keep the car on.
    Oh, and if you're in neutral and you put foot on gas just barely to keep the car on, the revs go up and down without changing throttle pressure.
    Columbus
    vacuum leak maybe? check all around your intake mani for hoses that are either torn, not attached. etc....
    or maybe your fast idle valve. its on the bottom of the throttle body.
    Newnan
    tps or map, does the car run like shit till around 3k then feel fine?
    Duluth, GA
    Quote Originally Posted by greasemunkey View Post
    No, it feels fine all the time. Unless it's out of gear.
    And I know I don't have any vacuum leaks.
    throwing any codes?
    My line of work
    www.internationaljets.com
    423 KING
    Chattanooga, TN
    sell it
    18x9 +24 18x10+22
    Duluth, GA
    Quote Originally Posted by lanning View Post
    sell it
    LoL.
    Would...but.... Well, you know the story.
    GWINNETT IS GREAT!
    messed up man
    Duluth, GA
    Any more advice?
    PURP-a-trader PURP's Avatar
    trade it
    Duluth, GA
    trade it
    Yeah, wish people wouldn't keep saying that. You just keep reminding me how IA Mod ogres delete threads without explanations.
    Really need advice on how to fix the problem!
    Fuck Your AC130 browningboy7's Avatar
    Dec 2008
    Quote Originally Posted by Captain-Obvious™ View Post
    You could just pay the for sell thread fee? lol
    bump wish had the cash for a tranny
    Epic Foxbody Thread Crew Member #01
    423 KING
    Chattanooga, TN
    have you checked the FITV and changed the thermostat
    18x9 +24 18x10+22
    NW Boonies
    tighten wax in the thermal valve... its under the tb.
    ~DB4LYFE
    07 Honda GD3
    NW Boonies
    lol almost the same time!! reps dude!
    ~DB4LYFE
    07 Honda GD3
    423 KING
    Chattanooga, TN
    http://www.superhonda.com/forum/f55/...oblems-259965/
    pretty good write up here daniel son
    18x9 +24 18x10+22
    revolution big mac's Avatar
    try maybe clean the trottle body out, and a new gasket. check high idle valve or fast idle valve(dont remeber which). check lines for leaks even a pinhole leak will cause it
    Duluth, GA
    Quote Originally Posted by browningboy7 View Post
    Wow. Just...wow.
    Senior Member G.C's Avatar
    Forgot
    Same exact problem happened when i had a prelude. It turned out the idle screw was messed with, the thread lock paint was broken so it was obvious someone messed with it. The idle was set too low, so when the car was warmed up the car will die. It will drive fine but when you come to a complete stop (redlight) i had to constantly keep on gassing it or else it will stall out. Man that shit was embarrassing hahah.
    Give it a shot, see if someone messed with it and if it has, adjust the screw so you will idle higher.
    Hope this helped.
    :idb:
