Results 1 to 19 of 19
Thread: Does anybody use this method or seen? Installing wheel studs
    FUK IT! bowdown201's Avatar
    Next Door
    Default Does anybody use this method or seen? Installing wheel studs
    Came across this earlier and was wondering if anyone else has done it this way?
    Yo face! SUBY_RUE's Avatar
    in the land of ozz
    People who do that are to lazy to do it the right way, I dont suggest it.
    For one hell of a life
    I got my girl got my family
    For a hell of a time
    HELLYEAH!
    in a paint booth
    ive done it that way before when i didnt want to replace the wheel bearing because it usually dont come out clean or if you dont have a press to press the hub out and back in
    GOON oneSLOWex's Avatar
    Chattanooga,TN
    It just looks like you are trying to fuck something up to me. I would suggest doing it the right way.
    Next Door
    ^^Thats not me in the pics I found them on the internet
    West palm beach
    Quote Originally Posted by SUBY_RUE View Post
    THIS
    Just remove the hubs and do it the right way, takes a little over an hour to do the whole car if you have the right tools...
    NO ADVERTISING
    -IA MANAGEMENT
    Next Door
    THIS
    Yea ive done 1 or 2 a while back but IIRC it was a bit of a bitch to get back in the hole. I know theres a spot on the hub that you have to turn where the stud will go in but just didnt know if anyone else has actually tried this.
    Cause I agree it does look a little sketch thats why I asked
    West palm beach
    Quote Originally Posted by bowdown201 View Post
    do you have oem or extended studs ?
    NO ADVERTISING
    -IA MANAGEMENT
    Next Door
    OEM. They are for the front also not the back drums.
    Sep 2008
    Newnan
    I've done it that way many times. Some makes already have the shoulder modified that way brand new. On a Honda, the torque spec is only 80 ft lbs so its not likely to pull through the hub anyways.
    Next Door
    Okay so how the hell do I get the lug OUT? I dont remember the clearance being this bad on my EJ.
    do what ya gotta do
    Next Door
    ^ Thanks for info! Im gonna get right on that!
    YOURMOM tnomud's Avatar
    Coweta
    Component parts are designed to be installed, removed, and used in a certain way. When you do this as a shortcut, you are essentially compromising that component.
    Hey, it's only holding your wheels onto the car, it's not THAT important, grind a little more off and use some hot glue to hold it on.
    Long Live GM! :^o
    Alpharetta
    Quote Originally Posted by tnomud View Post
    Next Door
    Component parts are designed to be installed, removed, and used in a certain way. When you do this as a shortcut, you are essentially comprimising that component.
    You obviously cant read too well. Thats not me in the pictures on the first post
    PURP-a-trader PURP's Avatar
    Just remove the hub, Travis. It's not a difficult task. Just takes a lil bit of time. You can do it. I believe in you. lolol
    You can get a press at harbor Freight for less than 100 dollars that will work to push out the bearings
    It was the best 65.00 I think I have even spent at harbor freight
    NO ADVERTISING
    Coweta
    no no no, I know that wasnt you. I was simply goofing on the stellar workmanship concept, not your efforts.
