Results 1 to 27 of 27
Thread: VTEC problem, in the opposite direction; kicking down instead of up....
    SwiperNoSwiping!!
    Default VTEC problem, in the opposite direction; kicking down instead of up....
    OK, im running with an lsvtec and it has ZERO problems going into vtec, but where its problem lies is coming off of vtec after im done driving it in vtec. I can tell it sticks because i hear the lower rpms sputter and idle horribly, and the valves all sound like they're still opening extra wide. A few seconds later, itll throw my CEL. I can turn the car off and as soon as i restart it, all returns back to normal.
    What could this be, do i need to replace the vtec solenoid plunger?? Or could it be an electrical thing, like i need to ground my oil pressure switch better? I have it grounded on the VC right now... lmk.
    u remind me of a wigger !
    2.2 CL
    That's weird...
    West palm beach
    dude, you have more problems then anyone. Do you not have any friends that work on hondas ? I wish you where on the south side, I would deff. come help you out...G/L bump
    NO ADVERTISING
    -IA MANAGEMENT
    YR88 Win! Romeo's Avatar
    Middle Ga.
    isn't this on a pretty new motor?
    sounds like an electical issue.
    My line of work
    www.internationaljets.com
    Middle Ga.
    Quote Originally Posted by Starrfire View Post
    I'm thinking the same.
    Wait, what CEL?
    My line of work
    Southside
    x2
    ѦʈʃѦŋʈѦ
    Joel's a good guy! Just his car has many problems! LOL.
    everywhere & nowhere
    What code is it throwing when the CEL comes on?
    Have you cleaned the screen on the noid?
    SwiperNoSwiping!!
    lol yeah, motor is pretty new, but the part thats not new is the vtec solenoid, etc. The oil psi sensor/switch is new though. And ill pull up what code it is next time it pops up. I remember checking it a long time ago, and i think it was either 21 or 22.
    LOL and its not neccesarily full of problems haha, i just want to get it 10000% sorted out so it runs almost absolutely perfectly, so i almost go looking for little issues here and there, just so i can fix them.
    21* Accord Civic CRV CRX Del Sol Odyssey Prelude
    94-98 ** 92-95 n/a n/a 93-95 n/a 93-95
    VTEC Solenoid Valve
    defective circuit or unplugged / defective solenoid valve
    * not a valid code if car does not have a VTEC engine
    ** not with V-6 engine
    22* Accord Civic CRV CRX Del Sol Odyssey Prelude
    94-98 92-98 n/a n/a 93-97 98 93-98`
    VTEC Oil Pressure Switch
    defective circuit or unplugged / defective oil pressure switch
    SwiperNoSwiping!!
    Quote Originally Posted by BABY J View Post
    VTEC Solenoid Valve
    Aha, 21 is it. lol.. thanks.
    I guess i just gotta replace the solenoid valve then, huh? or clean it out lol, one of those two things.
    2.2 CL
    there is one on here for sale i believe
    1st remove yours and clean the screen. Also - if you have a friend with one, run his and see if that's the fix. Then if it is - purchase the new/used one. Also make sure you are running good oil and are not low.
    2.2 CL
    and dont forget to change your vtec fluid
    ^^ LOL - yeah... that HAHA
    SwiperNoSwiping!!
    sounds good to me lol. ill check it out tomorrow.
    EDIT: but i know the oil is good and plentiful i just changed it 2days ago and its only been run for maybe 50miles lol including on the dyno
    slingshot sales ceo. ls-r teg's Avatar
    gwinnett
    i got some stock gsr cams if u want
    STILLHAVE THAT PENIS ?????
    They should have never gave u niggggas vtec
    GWINNETT IS GREAT!
    Quote Originally Posted by ls-r teg View Post
    SwiperNoSwiping!!
    LOL seriously though...
    they might actually help me out here...
    Make sure your wiring is correct, but since its just the solenoid, you can get one for $75 or less.
    My line of work
    GET It Ima HUSTLER youngmill's Avatar
    Some Where Gettin Money And My Women Be BAD. TalkIN Dollar Signs! I know You Heard About It.
    Quote Originally Posted by Romeo View Post
    Yeah it hasn't been that long sence u did the conversion. Take it to the person that did the conversion for u. If u did it ur self, then FYL. LOL GL FINDING YOUR PRO. Holla bak
    SwiperNoSwiping!!
    lol wut? there's no PROBLEMS with the conversion, I personally think its mechanical, like the solenoid plunger just gets stuck in the "vtec ON" position....
    well then, fix it. It is really easy to fix, you knew that before you made the thread.
    My line of work
    try a different ecu w/ your chip. just try it. it's ecu or other electrical. if the solinoid was sticking mechanically then it wouldn't reset itself when you turn off then back on.
    SwiperNoSwiping!!
    Quote Originally Posted by scttydb411 View Post
    Hm, i never thought about that....
    I may just try to re-ground the oil pressure switch in a different place with a heavier gauge wire first and see what it does...
    EDIT: i grounded the 18gauge groundwire on my oil pressure switch directly to the chassis, instead of on the valve cover, and it is MUCH better at coming off of vtec. It does still have the tendency, but its nowhere near as bad. It at least was smooth enough to not throw the CEL, but i could still tell it was still sending a slightly energized signal to my ecu, telling it to keep the vtak ON...
    I wonder, if i would need to use a little bit heavier of a gauged wire to get it to even more smoothly come off of vtec...?
