Thread: TW/FS - Viewsonic G90fb CRT Monitor
    2.0TRawr ironchef's Avatar
    Default TW/FS - Viewsonic G90fb CRT Monitor
    I'm looking to sell this monitor because I want to buy an lcd, and I'm trying to offset the cost of the lcd as much as possible lol. Anyways, heres the specs...
    Specifications
    CRT Type 19.0" (18.0" viewable) CRT, 90° deflection Dot Pitch 0.21mm horizontal, 0.14mm vertical, 0.25mm diagonal Phosphor RGB medium/short persistence Glass Surface Tint: TM~52.6%, anti-static, anti-reflection screen coating INPUT SIGNAL Video RGB analog (75 ohms, 0.7 Vp-p) Sync H/V separated (TTL), composite sync Frequency Fh: 30~97kHz; Fv: 50~180Hz COMPATIBILITY PC VGA up to 1920X1440 non-interlaced Mac®** Power Mac™ G3/G4/G5 1600x1200 CONNECTOR Analog 15-pin mini D-sub Power 3-pin plug (IEC320) POWER Voltage AC 90-264V, 50/60Hz (+/-2), auto switch Consumption 100W (typ) CONTROLS Basic Power, on/off, 1, down, up, 2 On View® Contrast, brightness degauss, H./V. size, H./V. position, pincushion, pinbalance, trapezoid, parallelogram, tilt, top/bottom hook control, V. moiré reduction, ViewMatch® (9300K, 6500K, 5000K, user), language, OSD position, memory recall, ViewMeter,® zoom VIDEO INPUT Bandwidth 202MHz (typ) MISCONVERGENCE 0.25mm (max) at center
    0.35mm (max) at corner DISPLAY AREA Factory Setting 352mm horizontal x 264mm vertical Maximum Scan 360mm horizontal x 270mm vertical (dependent upon timing signal) OPERATING CONDITIONS Temperature 32-104° F (0-40° C) Humidity 5-95% (non-condensing) DIMENSIONS
    (WxHxD) Physical 445mm x 457mm x 456mm
    17.5" x 18.0" x 18.0" WEIGHT Net 42.3 lb. (19.2 kg) Gross 49.4 lb. (22.4 kg) WARRANTY Three-year limited warranty on CRT, parts and labor. PRODUCT DIMENSIONS W/STAND 17.5"x18.0"x18.0" PRODUCT DIMENSIONS W/OUT STAND 17.5"x15.9"x18.0" SUGGESTED CONSTRUCTION PLANNING DIMENSIONS W/STAND 19.5"x19.0"x20.0" SUGGESTED CONSTRUCTION PLANNING DIMENSIONS W/OUT STAND 19.5"x17.9"x20.0" POWER MANAGEMENT Meets TCO'99 and ENERGY STAR® standards REGULATIONS UL/cUL, DHHS, FCC-B, ICES-003, TCO'99 (G90fB), TCO'03 (G90f), CB, ENERGY STAR®, NOM
    And a picture.
    Monitor is basically in mint condition, nothing was ever spilled on it, no cracks in the screen etc.
    Looking around, it sells for about $250 online new, so shoot me a reasonable offer and we'll discuss it. Local pickup or delievery only, no shipping. And no lowballers please, this is a very quality monitor, not some like no name brand piece of shit.
    TTT
    Bumpage. Got my new monitor today, someone take this one off my hands!
    $100 Takes it, some get it .
    yea bumpage again, $90 and you get it!!!?
    God Loves Tits & Jailbait God's Avatar
    Jan 2001
    65 w/ pickup?
    Thats a little low i think, it retails for $250 new. $85 w/pickup is probably lowest i'd go.
    Jan 2001
    how long have you had it? thanks
    Probably about right around a year or so.
