Ok, I have a 92 accord ex 4 door with an h23a1 swap in it. Car was running great till it sat for 6 months and someone stole the distributor. They cut the harness so I had to rewire the plugs going to the distributor. All connections are good, they have been checked and double checked. For some reason when the motor is cold the care will run great but when it heats up it will just shut off going down the road, turn the ignition off and cut it back on and its fine for about another mile then it cuts off again. This happened to me about 13 times tonight in a 20 mile trip. Check engine codes are no ignitor signal and crank sensor malfunction Any clue to what it could be?![]()
