Results 1 to 16 of 16
Thread: clinic 750cc injector
    about this far.
    Default clinic 750cc injector
    are they used for hondas? i just pick up a set of 750. LMK i will give reps for help!!!
    http://www.fuelinjectorclinic.com/cg...ey=IS115-0750H
    Imy ruckus
    ~Lagg Squad~
    <turbo negros>
    I put the sexy in dyslexia.
    R.I.P steven bond....
    Jul 2009
    IS115-0750H honda PART NUNBER...
    looks like you need injector ring kit too...... sometimes oem injector rings will leak fuel and you need to get fatter o rings...
    might wanna call and find out the specs..... in case you need a box
    about this far.
    Quote Originally Posted by dallasb84 View Post
    they came with the rings, and also where would the number be located on the injector? i can have pictures posted of them later tomorrow. also where can i find a box that plugs into the dead plug on the obd1 wiring harness?
    Imy ruckus
    ~Lagg Squad~
    <turbo negros>
    Jul 2009
    what dead plug are you talking about...... im lost...
    the part number is usually etched or scribed on the injector.... somewhere.
    known as Charles
    Quote Originally Posted by Tree View Post
    You just use the wires at the dead plug to add the resistor box if the injectors are low resistance. I dont think there is one that actually plugs into the dead plug. Just search "resistor box install" on honda-tech for a how too.
    As for finding a resistor box, you find them on MPFI efs and older accords and preludes.
    Main Stream Performance
    www.mainstreamperformance.com
    MSSracing.com
    about this far.
    Quote Originally Posted by Main Stream View Post
    ooo.. do you more about these injectors?
    Imy ruckus
    ~Lagg Squad~
    <turbo negros>
    known as Charles
    If you get the injectors in the link you posted then you will not need a resistor box. They are high impedence injectors so you just need to put them in and get tuned.
    MSSracing.com
    IA's Pedo-cord tdurr's Avatar
    Fayco
    i have a extra resistor box if u want it. give me half a tank of gas and its urs
    Save ur engines!
    about this far.
    Quote Originally Posted by tdurr View Post
    i might i will know tomorrow
    Imy ruckus
    ~Lagg Squad~
    <turbo negros>
    Fayco
    sweet. ill be outt town tho. soo like next tuse i prob could meet up
    Save ur engines!
    about this far.
    i should know by then.
    Imy ruckus
    ~Lagg Squad~
    <turbo negros>
    Fayco
    that works then.
    Save ur engines!
    Tuck'd & Swap'd Thundercat's Avatar
    Valdosta
    ~CREW LEGIT~IMPORTALLIANCE.ORG~All IN FAB~BISIMOTO
    Fayco
    stop that.
    Save ur engines!
    West palm beach
    Quote Originally Posted by Thundercat View Post
    why would you bump this ?
    NO ADVERTISING
    -IA MANAGEMENT
    about this far.
    so i can learn more.
    Imy ruckus
    ~Lagg Squad~
    <turbo negros>
