I have a 92 Lexus SC400 with a JDM 1UZ-FE engine swap as most of you know.
I went to start it Sat. before I headed out to Purp's house for the Cruise for Kids...
Anyway, I have no fire, and my fuel pump is not kicking on...
I replaced the dizzy caps (yes it has 2) rotor buttons, plugs, and wires. It seemed to run fine after that then started the same shit again...
Well I do a battery load test and find out I need a new battery, I change that and it runs good for the rest of the day...
Now, it's doing the same shit all over again and I'm lost!!!!!
I checked the fuel pump ECU its fine, so that means the pump is good as well because I can kick it on manually...
Someone said to check my crank sensor or that the Alt. might be bad, if anyone can help me out I will be happy to throw out some reps...
Thanks guys!!![]()
