Results 1 to 20 of 20
Thread: It's cold as balls!!!
    my momma's house
    Default It's cold as balls!!!
    When I cut the heat on in my car, it's not hot... AT ALL! Even when the car warms up, the air barley becomes warm... . It blows, and it sometimes gets hot, but more often then not, it only hits luke-warm. What could be the problem?
    Trend settin'
    no joke there is atleast 5 thread in the last 2 weeks asking this.
    PURP-a-trader PURP's Avatar
    check the heater core fool...
    eg6
    Apr 2009
    thermostat
    @thens!!!!! fools
    MY balls are pretty warm
    barrow county
    theres probably a clog in the heat core. little antifreeze goes into the heater radiator. there for you get little heat. try back washing the heater radiator.
    Duluth, GA
    At least you have the components for heat. Little bastards stole the shit outta my car.
    Kennesaw, GA
    x2
    Hwy 315
    what is this... air barley? some kind of grain?
    -jonathan
    [/URL]
    Jesus Christ is my Savior
    89 240 rmeyer114's Avatar
    Oct 2008
    snellville
    Quote Originally Posted by Captain-Obvious™ View Post
    Damn thats rough bro i feel for you my 240 didn't have heat components either it sucked ass lol
    95 mk3 jetta celebration edition
    -Rob-
    ѦʈʃѦŋʈѦ
    Just like you took out the a/c components out of the EG hatch! LOL.
    Check the thermostat.
    Scottish Scotsman's Avatar
    on the road to recovery
    wear long johns!
    Hwy 315
    Quote Originally Posted by SleeperWRX View Post
    ...check the thermostat? really? he said the car warms up.
    The issue is one of three things:
    1) your heater core is blocked/clogged
    2) the heater core bypass valve is not operating correctly
    3) the heater core hoses are incorrectly attached or not attached at all.
    Inspect those items and i promise you'll find the issue. If the hoses are not there at all, or are looped back around into the engine - use caution when connecting them and starting the engine up. They may have been done like that for a reason. (leaky heater core - too lazy to fix - lets loop the hoses)
    -jonathan
    [/URL]
    center field
    change thermostat could not be the rite one , or do u have 1 in there.
    my momma's house
    Thanks for the replies! I was told it could possibly be a sticky thermostat, but I wanted to get some other opinions. I've never really messed with my heater core, so i'm not too familiar with how it works and whatnot... . eh, i'll figure it out.
    Trend settin'
    my momma's house
    Not to be a dick, but where do you see ANYONE asking the same questions as me ANYWHERE in the last 2 weeks?
    Trend settin'
    known as Charles
    -jonathan
    Check this valve to make sure it is opening all the way. You can just reach down there with your hand and open it or have someone move the lever from hot to cold on the dash and see if the valve opens and closes.
    If you car is reaching normal operating temps and stays there then your thermostat is fine.
    Main Stream Performance
    www.mainstreamperformance.com
    MSSracing.com
    .....maybe its the coolant temperature sensor?
    IA's bass guy
    Nov 2009
    paulding
    99 tahoe, build in progress
    barrow county
    coming back to read this.... one answer.. WOW!
    ok 1, if thermostat is stuck it'll either run very hot or close to cold.
    ok 2, if there isnt a thermostat than the coolant will stay very close to cold.
    there is only 1 reason its not getting heat into the car!
    Quote Originally Posted by ash7 View Post
    -jonathan
