Results 1 to 2 of 2
Thread: 90 obd1 vtec boosted b16a swap ?'s
    fuck it thug it JdM_EJ2's Avatar
    the streets where we burn sweets,Gwinnett county hoe
    Default 90 obd1 vtec boosted b16a swap ?'s
    i got the rywire harness so its plug n play.what i need to know is will DA integra mounts work?or do i need swap mounts.same with shiftlinks can i use DA shiftlinks or do i need swap linkage? thats all i really need to get my baby out. Reps for any info
    and throttle cable,can i use my stock dx cable or do i need a Si cable
    thanks
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    You need aftermarket mounts and shift linkage. Holla at hasports or the hundreds of other companies that makes mounts. You can use the dx throttle cable, but I recommend an DA since it's MUCH shorter. If you need more help, check out www.eastcoastefcivics.com because we rarely check there section anymore.
