- shocks civic
- Rep Power
- 0
shocks civic
I think i have everything i need to lower my car i recently purchased a ez xr cam kit and its two little bolts and it says that it is use to correct camber wear but should i replace the stock shocks?do i need to?i have a 2001 honda civic 4 dr, i just didnt know if i absolutely had to replace the stock shocks or if some people leave em on i mean i was told i just needed a cam kit and the springs and thats it so some advice would be greatly appreciated thanx
- Rep Power
- 23
if you want to have any sort of performance, buy some aftermarket performance shocks; if you don't really care and want to bounce over bumps and lose traction then you're fine as it is. the camber kits are eccentric bolts that you use to replace stock bolts so an alignment shop can adjust them.
- shocks civic
- You may not post replies
- You may not edit your posts
Forum Rules
