Thread: Big fuel leak.
    Who it is!® zakkkaliscious's Avatar
    kennesaw
    Default Big fuel leak.
    This morning I started my car to warm it up, i went back in side and when I came back the garage smelled like gasoline. I backed my car up and turned it off. There was a 2 foot wet spot on the floor. I figured out it's leaking from one of the hardlines underneath the fuel filter where it meets up to one of the rubber lines. There is a clamp on the line. There was also a small spot underneath the car where I parked and if I primed the pump it still leaked out.
    I have a walbro 255 and a rb25. Is it possible that if the pump was primed a bunch of times without starting the car there was too much pressure in the system?
    What should I do!?!!
    Ridin' solo... n00bsrus's Avatar
    Augusta, GA
    i would recommend replacing all your lines, first and foremost. probably to hardlines rather than rubber hoses to avoid using clamps... union blocks are more effective and the auto parts store will have them for under $10 a piece. pipe benders for the hardlines are probably in the same price range. attach that sh!t to your existing setup and you should be fine. but don't take it from me... i'm just a girl that likes cars n' sh!t!!!! Good luck with the issue i hope ya get it worked out and i hope ya don't have to drop the fuel tank
    Drillin' switches on them bitches!
    Ridin' So Low...
    Quote Originally Posted by n00bsrus View Post
    You had to add the girl part I see.
    Augusta, GA
    it's been a minute since i've been on here... just had to remind everyone before they try to puff out their chests and swell up their balls at me lol
    Ridin' So Low...
    neg on the prime so any times thing.
    find where its leaking and fix it. doesnt sound all that hard to me. fuck all the changing of soft to hard lines. 9 time out of 10 u got a line that 10-15+ years old. shit breaks.
    kennesaw
    Yep the line is bad. Now I just gotta find time to replace it. Thanks girls and guys.
    Southside Ridin HATCH
    which line was bad?
    kennesaw
    The line that runs under the filter to my rail.
    Augusta, GA
    damn hope ya get it fixed and all works out well for ya... i had a fuel issue on my s10 last night... got no power to the fuel pump... i was all freaked out thinking it was a computer/security issue... turned out to be the fuel pump ground wire wasn't mounted on the frame... so no ground = no power for fuel pump = no start of my 4.3.... >_< i felt like an idiot for 10 minutes i swear...
    Ridin' So Low...
