Results 1 to 11 of 11
Thread: help car cut off on highway
    Certified Gearhead jdmmmm's Avatar
    Villa Rica
    Default help car cut off on highway
    I was driving down 575 and i noticed my rpm's were going up and down (and my gas was low(not empty). Then it just cut off. i tried to start it back up but it wouldn't. about 30 minutes later i started it up and it ran then cut off and 5 minutes later it ran then cut off. 45 minutes after that then the car starts up and runs i take it to the next exit and fill up and then i tried to get back on the interstate and it just stopped again.
    i wonder if its a fuel delivery(injection, filter, pump) issue or something else. cause it will start one day and the next it wont. Please help me if you have some insight.
    ѦʈʃѦŋʈѦ
    Probably your injectors, same shit happened to me.
    I personally think it's a fuel delivery(injection, filter, pump) issue or something else. Later, QD.
    center field
    maybe the dizzy
    vtakkk hondaxpurt's Avatar
    TALKING ROCK, GA
    1st-check for spark when having trouble cranking
    2nd-rent a fuel pressure gauge and test the fuel pressure at the fitting, which will tell you if its before the fuel filter or after the filter...
    3rd-check back in.
    98 Acura Integra LS-DD
    ??????????????????-project
    Apr 2009
    Villa Rica
    Not saying they are wrong^ it has happend to me and it wasnt the injector, filter, pump or spark plugs.... i had a bad ground that had a small nick in it and it would cause my car to bog or shut off because it was grounding everything out.... just figured i let you know so you could check that too!
    TALKING ROCK, GA
    Quote Originally Posted by a94civicex View Post
    also a possiblity. could be a million things, really...hell, could be a bad connection on a wire at the ecu for all anyone knows. start with the easy stuff first
    KINGZOFSOUTHTOWN
    Norcross
    Same happened to me...
    J/W what kind of car do you drive jdmmmm?
    -hmgdrfter-
    PP TRACK 350Z
    Apr 2009
    Villa Rica
    then i had a 94 escort gt, lol that was back in 2001....
    Villa Rica
    thanks for the help. i drive an integra
    NITROUS JUNKIE
    home
    check the main relay, happen to my accord, sometimes it wanna work sometimes it doesnt. and after i changed the relay always started right up
