Thread: New Procharger F4 Supercharger
    In High Definition!! DSGMach1's Avatar
    Sep 2008
    Default New Procharger F4 Supercharger
    Quote Originally Posted by mark@stangtv View Post
    When I came over to the Procharger booth first thing Thursday morning, I thought this was some kind of cruel joke. A supercharger the size of a trash can attached to the front of a big block Chevy, and it is nearly half the size of the engine itself. This is the new Procharger F4 supercharger and it even requires a minimum of 900 naturally aspirated horsepower to make it work.
    This blower is a gear drive only type system that is designed to make 3200+ horsepower, 45 psi, and flow over a hurricane-like 5400 cfm. The gear drive system on this blower is the same unit you will find on the F3. This is a limited production piece (obviously) and is designed for extreme drag racing. We heard that this blower was going to be tested soon, but no name was released. The one hint we had was “A previous NMCA Pro Street Champion”, which immediately leads us to think Mark Mickie.
    You can barely see the engine behind the blower!!
    "It's hard to believe that engine builders and racers are looking for even higher power levels and increased blower efficiencies than the F-3 models already deliver," says Jim Summers, Motorsports Director at ProCharger. "The F-3 has proven capable of 2,000 horsepower on pump gas and 3,000 horsepower on an engine specifically designed for use with a supercharger and running alcohol fuels."
    Make sure your cat isn’t walking buy when you fire it for the first time, it might just suck it in.
    NEW ProCharger F-4 Supercharger: specifications
    Volute Diameter: 16-inches
    Max HP: 3,200+ HP
    Base NA HP: 900-1,400 HP
    Max Flow: 5,400 CFM
    Max Boost: 45 PSI
    Inlet Hose Dia: 7-inches
    Inducer Dia: 6.32-inches
    Exducer Dia: 8.89-inches
    Outlet Hose Dia: 5-inches
    Outlet ID: 4.26-inches
    Max Impeller RPM: 55,000 RPM
    Internal Step-Up Ratio: 5.63:1
    Reverse Rotation Available: Yes
    Self-Contained: Yes
    Oil Capacity: 4 ounces (larger capacity available for extended run-time applications)
    For comparison: ProCharger F-3R-139 Supercharger specifications:
    Volute Diameter: 12-inches
    Max HP: 2,700+ HP
    Base NA HP: 700-1,000 HP
    Max Flow: 4,000 CFM
    Max Boost: 45 PSI
    Inlet Hose Dia: 6-inches
    Inducer Dia: 5.47-inches
    Exducer Dia: 7.20-inches
    Outlet Hose Dia: 4-inches
    Outlet ID: 3.59-inches
    Max Impeller RPM: 62,500 RPM
    Self-Contained: Yes
    More information will be eventually found on www.procharger.com
    :idb::idb:
    Northwest Georgia
    yeah id say that is wild
    SICK
    My friend texted me that while he was at PRI. I'm glad to see the specs!
    Zen Motors LLC
    Local Phone:770.904.2868
    E-Mail: [email protected]
    Website:www.ZenMotorsLLC.com
    C7 On_Her_Face's Avatar
    Duluth
    Yeah reminds me of the blowers on Funny Cars/Rails they take over 1000 horsepower to turn the supercharger.
    ALL BUSINE$$ RedGTS's Avatar
    Cartersville
    holy mother of god
    1992 Acura NSX
    2014 Cadillac ATS
    2002 Z06
    2011 ZR1
    1969 Camaro Z28
    930 turbo
    2000 integra type r
    11
    JDM TYTE AnthonyF's Avatar
    A friend of the family had the F2 Procharger for his Viper. It wasn't enough so he went to TT to make 2k hp...
    Procharger makes the best and sexiest superchargers.
    -Ant.
    The Carbon Fibered R6
