Traction Control assembly and traction control ECU 100 shipped
Stock 6speed ECU OBD I 250 shipped
2 sets of stock supra cams with both less than 30k miles 175 per set shipped
1994 headlights in good shape 200 shipped
Stock tranny mounts w/ 62k miles - 30 shipped
Stock motor mounts w/ 62k miles - 45 shipped
Stock Clock - 20 shipped
Boostlogic 4in Downpipe 425 shipped
MT ET Drag radials. Only seen 10-15 passes. Lots of tread left and perfect for stock wheels. 275/40/17 250 can ship but would prefer local pickup in atlanta
Apexi N1 exhaust 350 prefer local pickup unless I can cut it in half to ship
US 2JZ-GTE longblock I made 801rwhp and 701 rwhp @ 30psi on a 71gtq w/ 264 cams. Motor has 25k miles on it. Smokes white at startup. I think its the valve stem seals. Removed from car to install built motor - $2700 with stock cams $3300 with HKS 264 intake/exhaust cams
94 dash piece to left of steering wheel w/ two holes cut out for VPC/GCC and for a 60mm gauge $35 shipped
AC Control Unit (buttons and knobs) 200 shipped
AC amplifier unit (mounts on top of stereo) 200 shipped
AC compressor 75k miles 175 shipped
AC condenser bought from (DrivenFaster on SF) 75 shipped
Stock Fan clutch with blades 125 shipped
Walbro fuel pump w/ 2k miles 100 shipped
2 Walbro fuel pump install kits 10 shipped each
Stock fuel sender unit in excellent shape 100 shipped
71gtq turbo - Used it for 7 months and when I removed it the compressor wheel had a little nick in it and there was oil build up in my intake pipe where it attached to the compressor housing. still made good power when I took it off - 400 shipped
T66 hot side .81 a/r housing - 100 shipped
Tan rear seats in good condition - 30 bucks picked up locally
2 Stock timing belt tensioners 1 w/ 60k miles and 1 w/ 25k miles - make offer
Stock intake manifold/ throttle body - make offer
Stock lower runners - make offer
Thanks,
Clark
