Results 1 to 14 of 14
Thread: offset question
    Default offset question
    i have a quick offset/tire question. i know that if i have a 15x8" wheel with a 0 offset i need to run a 195 45 15 tire. the wheel that im looking at is a 15x7" with a +10 offset and im wondering if i would be ok if i ran a 195 55 15 tire and be ok. any help would be great.
    ccw replicas
    kennesaw
    offset will not matter what size tire you run. it will just have a bigger sidewall. compared to the other tires
    HF
    in da clouds
    dnt run anything bigger then a 195 50 15
    roberta
    what he said,id run a 165/45/15 if yu want stretch or a 195/45/15 for a nice look
    tawksick. toxxxic's Avatar
    Roswell
    LOL why the hell would you stretch a tire on a 7 inch rim?!
    Some people even run 205's on 7 inch wide wheels.
    205/50/15 if you want a beefier look
    195/45/15 if you want a regular low profile but still filling the gap look.
    but it still depends what car you're putting them on, whether its going to look good or not.
    C7 On_Her_Face's Avatar
    Duluth
    Quote Originally Posted by toxxxic View Post
    Why the hell would you stretch a tire on any rim? Ohh yeah cause people like the looks. However it serves no purpose at all lol.
    iTouge HillClimbGuy's Avatar
    snellville
    if you have a 15x8 wheel go with a 225 wide tire or it will look funny why pay for extra wheel if you are not going to use it
    oh and stretched tire does have a purpose it will help you bend up your wheel super fast
    Ballerness is like butter you just can't blob it in one place you got to spread that shit around
    sorry guys. its going on a 99 si and the car is slammed. im not wanting to bring the car up any at all. i know the tire will fit because its on my stock wheel which is not 7" wide and doesnt have a +10 offset.
    YOURMOM tnomud's Avatar
    Coweta
    I have a 205/50 on my miata with a 7.5" rim and its anything but stretched
    Quote Originally Posted by tnomud View Post
    it doesnt matter how wide the wheel is. the normal offset for my car is about +40 im looking to run +10 which is lower. im going to run a 195 but i wanted to know if i could run a 55 series.
    Coweta
    Quote Originally Posted by blown_ss View Post
    Offset has nothing to do with how streched the tire is. Offset will widen the stance of the wheel on the car, but not affect the tire.
    I 55 series will be a taller sidewall than a 50 series. If you are looking to get that streched tire look, run a wider wheel, narrower tire, and lower profile tire.
    Keep in mind, these extreme tire streches are cool to look at, but make the tire very fragile and it will not operate as intended. A sidewall is part of the casing structure and designed to function at a certain angle. This is why most tire application guides have a "suggested wheel width" section.
    been there and done that. i've already had a setup like that. im not looking for a stretch look i want to fit the wheels on the tires that i have end of story. due the the fact that the wheel is a +10 offset it pushes the wheel more towards the fender.
    Coweta
    ok, I misunderstood..........
    yeah, staggared is the way to go on most cars..
    did in on my wifes ride....
    however, on my M3 (staggared from factory), i reverted to a square setup....
    GoooooooooooN shane94's Avatar
    Gainesville/Oakwood/Flower Branch
    if your going to do 15x7 wheel then you should go with a 195/50/15,195/55/15 or 205/50/15... if your going to do a 15x8 wheel then you need to do a 195/45/15...
    if you want a idea of what 195/45's look like on a 15x8 wheel here you go
    Fs/Ft: Sportmax 501's 15x8 +15offset
