Results 1 to 13 of 13
Thread: hellllllllllpppppppp
    IA Member typercb7's Avatar
    lithonia Geogria
    Default hellllllllllpppppppp
    hey guys i just finshed my swap and my car is doing this .........this video is not my car by its doing tha same thing look it up and tell me what u thing tha only thing different with this car and my car is that mine is obd 0
    some one plz help
    http://www.youtube.com/watch?v=BSQFBTyRPOs
    vanilla sky.
    ecu,limp mode/
    aye bro .:Stirfry:.'s Avatar
    x2.^
    or switch your map and tps, try that out first
    ATL DAsquad Member #9
    word or dizzy but try switching plugs first
    Quote Originally Posted by .:Stirfry:. View Post
    x2.^
    ATL DA SQUAD MEMBER #1
    HONDA_PARTS_CLEANUP_CLICK_ME
    lithonia Geogria
    Quote Originally Posted by jadakid88 View Post
    what do u mean ........
    check and make sure all the plugs are in the right spot.
    or check the dizzy
    lithonia Geogria
    what dio u need to cheek on tha distruber
    the duckster
    Rome
    launch control
    Race Ready Developments Member #5
    Rome Crew
    chamblee
    sounds like condesation in the dizzy cap try some wd40 and clean it out
    SwiperNoSwiping!!
    Quote Originally Posted by ducky1177 View Post
    launch control
    lmao
    u remind me of a wigger !
    Aug 2009
    DOUGLASVILLE
    launch control
    SWEET LAUNCH CONTROL! where did you get it? j/k man um have no clue for real that sound like you maybe did plug somthing up wrong in you ignition, just back track youself and go from there!
    Senior Member WalkS's Avatar
    Middle Ga
    x2.^
    I concur , or like someone else said, look into your distributor
    launch control
    Haha! Had this exact same problem on my D16, and it was building 4psi on the 3.5 rev limiter, changed out the tps worked fine after that. I got a video of it too!
    JJSPEC Racing
    IA Member 69goldenone's Avatar
    newnan
    I did the same swap and hade a problem too. You may need to bypass the resiter box for the injectors. The newer engines didn't require it. But its just a suggestion. Hope it works out
