Thread: Forks overhaul/service
    JDM TYTE AnthonyF's Avatar
    Default Forks overhaul/service
    I heard from others I should prob change the fluid out in my forks. Since I wont be riding for awhile I figure why the hell not? I've got 22k on my '06 R6 and I know i need the valves adjusted which I believe ASE*TECH is going to do it for me. I trust him and love him. WHAT?
    How hard is it to change the fluid and what kind/weight should I use? (if they even come in weights/thicknesses)
    -Ant.
    The Carbon Fibered R6
    IAs Most Hated OG!! BLK JDM's Avatar
    Man I see you riding your R6 all the time on North Druid Hills. I'm always in a car so I don't want to scare you. How many miles did you buy the R6 w/?? You've been doing some serious riding. I know you're a tech but I'd check out Marietta Motorsports. They are very knowledgeable. I have a friend that races R6s & R1s in AMA & WERA. He works on so many Yamahas he makes me very comfortable. He's a Yamaha nut. If you want his number PM me. He did most of my work when I had my R1.
    Quality Perfomance and Fabrication!!
    Johns Creek
    Huey at Marietta Motorsports
    Rob at MSP Cycle
    Traxxion Dynamics
    GMD Computrack in Jasper
    Any of them can do it for you.
    Quote Originally Posted by BLK JDM View Post
    I bought it with 12k or 14k and it's at 22k in 6 months. lol Def beep next time, I'll try not to get angry and give u the finger. lolol. I work off of Buford hwy right near N. Druid Hills.
    Thanks man. I need to get 2 stands so I can start pulling the bike apart. I'll PM you about it in the future. +40
    Quote Originally Posted by David88vert View Post
    Rob at MSP Cycle
    Traxxion Dynamics
    I guess no1 wants me to do it myself? lol I appreciate the help fellas. I will give them each a call when I get them ready to be worked on.
    -Ant.
    Riding for Alzheimer dazn's Avatar
    atlanta
    Quote Originally Posted by AnthonyF View Post
    -Ant.
    its not that bad to do as long as your careful about putting things back together.
    make sure to replace the fork seals while your in there. you can go thicker oil and change springs around, ask one of those ships listed and they can guide you in the right direction as far as spring rates and oil viscosity go. you will also need to clean EVERYTHING well and be careful measuring the amount of fluid you put back in. you cant just dump the oil out, youve gotta disassemble it all and clean.
    An experienced tech can easily do this. get a r6 manual from the forums and it will help loads. good luck!
    Let me know my boy will probably be a little cheaper than a shop. Like I stated he's a Yamaha nut and has the same year R6 that he built from a total wreck. He races it in WERA and AMA and actually normally finishes in the top 5 in his class. He'd be my top pick just because he specializes in the R1 & R6. But just let me know.
    You could change the oil yourself, but I'd just take it to Kent @ G.M.D. He knows his shit, and can answer any and all your questions regarding suspension.
    still searching! Hondatwin23's Avatar
    Atlanta\Lithonia
    how much does this usually cost
    http://twitter.com/LEGEND_STATUS
    1997 w/1999 civic w/ Built GSR...FS/FT
    Quote Originally Posted by dazn View Post
    its not that bad to do as long as your careful about putting things back together. !
    I've put engines together to specific clearances...that's a pain in the ass.
    But thanks homey. I got 2 pitbull stands now and Going to take some1's advice in here and get some1 to do them for me. Getting new headlights, more LED's, and powder coating somethings.
    -Ant.
