Results 1 to 40 of 79
Thread: HOW TO PAINT WHEELS! the cheap way
    IA Member SRK420a's Avatar
    Lithonia,Ga
    Talking HOW TO PAINT WHEELS! the cheap way
    This is my first DIY so I hope I'm doing a good job for a noob good luck to myself i had these pics lying around so imma try this for my first time.
    Materials:
    1. wheels
    2. bucket of warm water
    3. SOS pads,Soft Scrub, and/or Scotch Brite pad
    4. Towel and/or air gun to help dry
    5. Your choice of paint color spray paint works trust me, and clear coat spray
    6. a stand to set the wheels on
    7. patience lol
    8.wetsand paper 2500 grit
    Ok lets get started.......
    Here are my wheels i used a set of 3rd gen eclipse rims
    Step one: Clean the rims, very important
    Use the bucket of warm water and the SOS pad to clean all of the dirt,grime and gunk of off the rims, if not it will show up in paint......
    Step two: Dry off the rims using the towel and the air gun if you have one. If not be patient and continue using the towel
    Step three: Get some new warm water in the bucket, get the soft scrub and the ScotchBrite pad. Go to town on your wheels
    ( the soft scrub and SB pad serve to scuff up the rims and get whatever dirt was left behind).
    once you have scrubbed to the point where you can see very visible scratches over the entire rims its time to prep for paint.
    Step fourry off your wheel and if you have wax&grease remover use it now. unfortunately everyone doesn't have any so just dry em off and keep yourself from putting your hands on them plz! Once you've done that tape off what you don't painted and mount them on a stand for paint.
    (You can also paint your center caps as well)
    Step five: Paint or apply your first coat of paint or etching coat. Once dry check for any specs of dirt. If ok continue to apply coats of paint (maybe about 6 layers for protection.
    Step six: once they are dry check for fish eyes and runs if you see none good job. about 6 hours for complete dry and cure, then wet sand them rims with 1000 grit and prep for clear coat the same way you prep for the paint. Once dried apply around 3 to 4 coats of it then set it out to dry.
    Step 7: After they are completely dry wet sand them with 2500 grit or just wash them once their done
    Once your done you should get something like this.....
    I hope i did an ok job if I need to correct something help me i wanna be a benefit to IA even though I'm young and Noobish
    PURP-a-trader PURP's Avatar
    or you can clean wheels.. sand with 320... clean again.... spray primer... let it get tacky... spray base coat/coats... spray clear if desired... put back on car and ride out...
    Lithonia,Ga
    True i guess just puttin this up here because i didn't see a DIY for wheels and this is how i did it
    Duluth, GA
    Or, buy wheels in the color that you want....
    Ok, sorry.
    /Assholeness.
    lol @ricer v.cpt obvious
    wherever
    Clean dirt and brake dust off? I always thought that helped the paint sick to the wheels!
    02' Miata
    silly rabbit, brake dust is strictly for EDM
    Earth
    Holy bent rims Batman!!!!!
    Lithonia,Ga
    lol yea they were a bit bent but still sealed and i got them for free so cheap upgrade from stock wheels
    Lithonia,Ga
    Quote Originally Posted by Captain-Obvious™ View Post
    Ok, sorry.
    /Assholeness.
    Just showing a cheap way to make factory cooler so....... yea buying wheels the color u want does serve as a more permanent solution but you cant say its a bad idea... if you can find some cool stock wheels and paint em its still a cheap upgrade
    Northwest Georgia
    atleast you dont have tires on there, im sick of seeing rims painted with the tires still on, ATLEAST BREAK THE BEAD AND GET SOME PAINT IN THERE!
    ballin on a budget hondalover00's Avatar
    ga
    jon should get a kick out of this
    Lithonia,Ga
    Quote Originally Posted by SPOOLIN View Post
    thanx man idk y they thinked this is riced i worked hard on it and i know what im doing for a changed but o well... and who paints with the rims still on the tires?
    cravin a s2k
    Cookeville, Tennessee, United States
    ^^^ i do. index cards make that job easy, especially if you are leaving a polished lip on the wheel.
    Quote Originally Posted by LSTurboHatch View Post
    TAT-GUY EL42's Avatar
    Notorious Tattoos
    good job,man. i so need to repaint my wheels....and so many other things.
    Lithonia,Ga
    Quote Originally Posted by EL42 View Post
    Thanx dawg
    the county
    pretty good write up. i pretty much did the same thing on a set of Si's. painted the inserts black with the rest polished.
    Lithonia,Ga
    Quote Originally Posted by Master Shake View Post
    thanx man rep^
    West palm beach
    Quote Originally Posted by hondalover00 View Post
    pm ash7....he'll know what to do
    you say this in every tech thread, Who the fuck is ash7 and why are you on his nuts so hard ?
    NO ADVERTISING
    -IA MANAGEMENT
    Lithonia,Ga
    I sure dont know who he is but do you like the thread???
    Oct 2008
    Bankhead
    To me it actually looks good to be that cheap wal-mart spray paint
    Southside of The Jungle
    The way Southside does itOr I just polish dat hoe
    Ps-I used walmart 96cent paint for the insides.
    livin again collins's Avatar
    chillin in the sloooo gtoooo
    nice write up. and yes, dopple, you have to add in all the idiot steps so you dont get people saying "dude i painted them just how you said to and it fucked everything up! wtf man!?!"
    op: "did you clean them?"
    other dude: "naw man, you didnt say i had to clean them! you're an idiot and a liar!!"
    ~facepalm~
    Lithonia,Ga
    Quote Originally Posted by collins View Post
    ~facepalm~
    thanx man
    Brings da fuckn heat Lurker's Avatar
    Aug 2009
    on the phone
    nice
    Lithonia,Ga
    Quote Originally Posted by Lurker View Post
    nice
    thanx
    YoTa_BaNgEr YoTa_BoX's Avatar
    Dec 2003
    In a Yota
    Nice DIY right up man, Its cool to see people taking time to do stuff like this.
    Good contribution to the website
    Life is a thought, think about it.
    Lithonia,Ga
    Quote Originally Posted by YoTa_BoX View Post
    thanx man
    IA Member lama08's Avatar
    Good simple thread.. bump for reading
    Lithonia,Ga
    Quote Originally Posted by lama08 View Post
    thanx man reps for appreciating
    I'm Glad I'm Human CHRISNITTOLO's Avatar
    Oct 2009
    Stockbridge? Ellenwood?
    Dude... they look nice... they look powder coated or something... thanks for this thread...
    Quote Originally Posted by tdurr View Post
    sigged.
    Lithonia,Ga
    Quote Originally Posted by CHRISNITTOLO View Post
    thanx man
    Gsr-sol
    Dec 2008
    Warner robins, Georgia
    Index cards work great as long as it's not windy
    Jdm S15 Psw Jdm's Avatar
    Sep 2008
    Atl
    i took forever doing mine, sand sand sand and if you still want ur chrome lip use painters tape and wrap them bitxches up. but nice and simple write up.
    Slidin Sidewayz...
    Lithonia,Ga
    Quote Originally Posted by Psw Jdm View Post
    thanx man got any pics of how they look wen you painted em?
    Lithonia,Ga
    i did a good job i dont care what abybidy says lol
    lol warm water is only going to clean off water soluble grime but brake dust, rubber, & oily finger prints will remain. The surface must be cleaned with paint thinner or mineral spirits for the paint to properly adhere.
    I would recommend not painting the edge otherwise the paint may still come off when the tire is mounted. The wheel may be put in a oven after painting to harden it and speed up the curing process.
    Lithonia,Ga
    Quote Originally Posted by speedminded View Post
    I actually used wax and grease remover
    BMW Bastard MINI's Avatar
    Rome
    Good step by step for those who have no idea what theyre doing lol.
    And yours turned out very very well.
    Got a MINI? Don't talk to me.
    FUCK your FADS
