Results 1 to 13 of 13
Thread: Need help with my 350z!!!!!!!!!!!!!!!!
    Default Need help with my 350z!!!!!!!!!!!!!!!!
    i need some help my 05 350z is leaking coolant it isnt the hose and its not the thermostat housing or gasket changed all that already any ideas of what else it could be
    West palm beach
    could be a number of things, No way to tell with out looking at it or more info....
    NO ADVERTISING
    -IA MANAGEMENT
    AccuracyPerformanceAutomotive
    Water pump, radiator, heater hoses, .....
    500whp of spinnin fury!!!
    water pump is the next step im not working on the car its my cousin and basically trying to give him other ideas of what it can be but he said maybe the water pump do you know around how much water pumps run
    Quote Originally Posted by QWK D16 View Post
    I went to Nissan, and that's when the coolant started leaking. They said it was either the thermostat housing or the block. I was like "shit"... They charged too much to change the thermostat housing- like $320. So I bought the part and had my cousin change it. However, it's still doing it. Do you think it could be the block? I don't think it could be that, but I don't know why Nissan would have said that.
    Sandy Springs
    It cant be the water pump because its contained behind the front covers, Your oil pan would fill up with coolant if it was leaking.
    But like said before, there are so many possibilities as to where it is coming from.
    What area of the engine is it leaking from??
    Senior Member sprix!'s Avatar
    Quote Originally Posted by da1984 View Post
    fix'd. Run on sentences are bad.
    G37s 6MT/coupe
    Loves Twinkies Schroeder's Avatar
    Oct 2009
    In the Garage
    Freeze Plugs? I don't even know if the 350Z has the push out or screw in style.
    The Shitbox
    lol thanks, Any more ideas of what it could be.
    do a coolant compression test. it will tell u right where the leak is.
    Hey I thought I would let everyone know that I got the Z fixed and it was the water pump thanks for the help everyone
    Oct 2009
    In the Garage
    good deal!
    The Shitbox
    aye bro .:Stirfry:.'s Avatar
    x2 works every time
    ATL DAsquad Member #9
