Thread: OBD-0 CRX check engine light
    Yeah its a 4 door
    Default OBD-0 CRX check engine light
    i just got this 90 CRX yesterday, it runs and drives fine but when i go over 70mph the check engine light comes on. it doesnt stay on, just when im at 70mph and above, its a stock d15 in it. how do i check the engine codes on this OBD-0 crx??? is it a jumper connector under the dash just like an OBD-1 car????
    Repent or Perish jdm_crx_man's Avatar
    McDonough
    the ecu has a red light that flashes quick blinks=1 long blinks =10 ex. one long blink,one short blink =11 the google the cel number and it will tell what is wrong with the car...its very simple...gl
    edit: here ya go......(the number represents number of flashes from the ecu error light)
    Identifying the Fault Codes.
    The number corresponds to the number of flashes.
    1 Oxygen Sensor "A" (Primary) defective circuit or unplugged / defective sensor
    2 Oxygen Sensor "B" defective circuit or unplugged / defective sensor
    3 Manifold Absolute Pressure (MAP Sensor) defective circuit or unplugged / defective sensor
    4 Crankshaft Angle Sensor (CAS) defective circuit or unplugged / defective sensor
    5 Manifold Absolute Pressure (MAP Sensor) mechanical problem / disconnected piping
    6 ECT Sensor (Engine Coolant Temperature) defective circuit or unplugged / defective sensor
    7 Throttle Position Sensor (TPS) defective circuit or unplugged / defective sensor
    8 TDC Position (Top Dead Centre Sensor) defective circuit or unplugged / defective sensor
    9 CID Sensor (Number 1 Cylinder position) defective circuit or unplugged / defective sensor
    10 IAT Sensor (Intake Air Temperature) defective circuit or unplugged / defective sensor
    11 CO pot
    12 EGR Lift Sensor (Exhaust Gas Recirculation) defective circuit or unplugged / defective sensor
    13 APS Sensor (Atmospheric Pressure Sensor) defective circuit or unplugged / defective sensor
    14 IAC/ISCV Valve (Idle Air Control/Idle Speed Control Valve) defective circuit or unplugged / defective sensor
    15 Ignition Output Signal missing or defective ignition output signal
    16 Fuel Injector System defective circuit or unplugged / defective fuel injector
    17 VSS (Vehicle Speed Sensor) defective circuit or unplugged / defective sensor
    18 Ignition Timing
    19 Automatic Transmission Lock Up Control Solenoid Valve defective circuit or unplugged / defective solenoid valve
    20 Electrical Load Detector (ELD)
    21 VTEC Solenoid Valve defective circuit or unplugged / defective solenoid valve
    22 VTEC Oil Pressure Switch defective circuit or unplugged / defective oil pressure switch
    23 Knock Sensor (KS) defective circuit or unplugged / defective sensor
    30 Automatic Transmission Signal: "A" / SEAF / SEFA / TMA or TMB
    31 Automatic Transmission Signal "B"
    41 Primary Oxygen Sensor – Heater circuit malfunction on D16Z6, D16Z7 and B16A2 engines
    41 Linear Air Flow (LAF Sensor) heater malfunction on D15Z1 engine
    43 Fuel Supply System defective or malfunctioning fuel supply system
    45 System Too Lean or Too Rich malfunction in the fuel monitoring systems
    48 Linear Air Flow (LAF Sensor) defective circuit or unplugged / defective sensor
    54 CKF Sensor (Crankshaft Speed Fluctuation) defective circuit or unplugged / defective sensor
    58 TDC Sensor 2 (Top Dead Centre) defective circuit or unplugged / defective sensor
    61 Oxygen Sensor, Heated - Sensor 1 (Primary) high voltage, low voltage, or slow response
    63 Oxygen Sensor, Heated - Sensor 2 (Secondary) high voltage, low voltage, or slow response
    65 Oxygen Sensor Heater (Secondary) malfunctioning or defective oxygen sensor heater
    67 Catalyst system Efficiency Below Threshold malfunctioning or defective catalyst system
    70 Automatic Transmission malfunction with the automatic transmission controls
    71 Cylinder 1 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
    72 Cylinder 2 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
    73 Cylinder 3 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
    74 Cylinder 4 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
    75 Cylinder 5 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
    76 Cylinder 6 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
    80 Exhaust Gas Recirculation insufficient flow detected
    86 ECT Sensor (Engine Coolant Temperature) circuit range / performance problem
    90 Evaporative Emission Control System leak detected in the fuel tank area
    91 Fuel Tank Pressure Sensor low input.
    92 Evaporative Emission Control System insufficient purge flow
    He Alone Is God...Prepare For His VICTORY!!!
    ls/vtak slut! SlamminCRX's Avatar
    Hinesville/Savannah, GA, Orlando, Florida
    yea the obd0 ecu's have a light on the ecu itself, just gotta read the codes
    vanilla sky.
    non-obd
    General Tech Hater
    Quote Originally Posted by silverDA View Post
    non-obd
    THANK YOU!! theres no such thing as OBD-0
    Southside of The Jungle
    Quote Originally Posted by MidLifeCrisis View Post
    You know what he meant though right?Dont gotta be a asshole everybody doesnt know that its OBD0 and not OBD-0
    West palm beach
    Quote Originally Posted by southside View Post
    x2, asshole
    NO ADVERTISING
    -IA MANAGEMENT
    General Tech Hater
    You two are retarded, its not called OBD-0 or OBD0.. it was just called PGM-FI, OBD-I was the first time they used those letters.
