This is very odd to me, i finally finished wiring up my 4wire oxygen sensor back into my car, and that's when all the craziness started:
at first when i turned the key to the ON position, the Main Relay under the dash was vibrating, and not pumping fuel as it should've been...
second, after i finally somehow got the main relay to stop vibrating, the next thing that happened was, almost all of the lights in the dash stopped coming on. The only light in the dashboard that illuminates when i turn the key to the ON position is that of the battery light. The Check Engine Light doesnt illuminate when the fuel pump is priming either, but i can definately HEAR the pump doing what its supposed to be doing. its driving me, im not really sure what this could be... other than the obvious fact that its an electrical issue of some sort..
