Thread: no heat
    xxxx mirz833's Avatar
    Duluth
    Default no heat
    It is a 1996 accord and my heater hose was leaking so i replaced it and now i got no heat even when the car is at the normal temp.The heater hose is hot when i touch it before fire wall so i just dont know any one has any ideas
    Quote Originally Posted by mirz833 View Post
    low on coolant, bad thermo, blocked heater core, water pump
    www.jjspec.com Macon, Ga
    Check to make sure the cable is on the water valve in addition to those things that Barefoot mentioned. He covered most of it.
    barrow county
    the hose goes into another radiator like thing, maybe when you changed the hose and added antifreeze, there's air bubbles in the heater radiator.
    NW Boonies
    x2
    ~DB4LYFE
    07 Honda GD3
    vtakkk hondaxpurt's Avatar
    TALKING ROCK, GA
    x3 plus check heater control valve. Barefoot seems to know a thing or two about honduhs...
    98 Acura Integra LS-DD
    ??????????????????-project
    Canton
    Quote Originally Posted by blue_gt View Post
    DING DING DING, check the simplest stuff first then spend money.
    Try not. Do or Do not.
