Results 1 to 40 of 51
Thread: Think Miatas Are Feminine? Think Again... Matt Andrew's Time Attack "Flyin Miata"
    Smile Think Miatas Are Feminine? Think Again... Matt Andrew's Time Attack "Flyin Miata"
    1. Little Miata hanging in with the big boys
    2.
    3.
    4. In action at Willow Springs
    Time attack – the words evoke so many more, like blood, sweat and tears. It’s the ultimate time trial competition on a road course, in which high-budgeted, race-bred vehicles go against homemade commuter cars-turned-lap-eating monsters. Time attack is about as serious a motorsport as they come, and any competitor will tell you the same. Just ask Matt Andrews.
    Andrews knows what it’s like to work from the bottom up, having taken a $1,700 non-running beater of a 1999 Mazda Miata and turning it into an aggressive time attack competitor. Don’t let his choice of a rough-around-the-edges platform give you the wrong idea – Andrew’s personal car history is dotted with performance cars, from AMG cars, Porsches, Toyota Supras, and of course quite a few Mazdas.
    The build for the ’99 Miata was a methodical one towards perfection, a systematic progress from point A to B, yielding results that have put Matt in major contention for several titles in the Modified RWD class.
    The exterior of the Miata is an especially bold blend of carbon fiber and aero, helping the roadster look like a mini RX-7. Weight was trimmed to a ridiculous 1,995 lbs. (minus the driver) through the use of a Racing Beat Type II front nose and Axis Power’s dry carbon-fiber magic, namely a lightweight hood, hardtop, front fenders, doors, trunk lid and rear bumper cover. In addition, an APR front splitter, APR GT-200 rear wing, and AWR racing rear splitter were also added to provide downforce.
    AWR was brought in to stiffen up the chassis and make sure Andrews was protected. They seam welded the passenger compartment, installed a custom 18pt. cage, gusseted the chassis, lightened the body and conducted all the aluminum work.
    Suspension-wise, Flyin’ Miata urethane bushings were added in addition to Flyin’ Miata rear top hats. A V8 Roadsters tubular front sub-frame was used, which featured updated suspension pickup points. Robert Fuller of RobiSpec installed and tuned the triple adjustable mono-tube coil-over dampers with external reservoirs and KW helper and main springs.
    Helping this Miata fly is a Garret GT2871R turbo-fed Flyin’ Miata 2.0L stroker engine built to spin to 7,500 revolutions. The engine block was built using a Moldex crank, pistons and rods, with the head featuring Flyin’ Miata 1mm oversized intake and exhaust valves. Stopping the motor from detonating are 750cc injectors fed by a Walbro 255lph fuel pump and everything controlled by a Hydra ECU.
    The turbo is fed via Boostlogic tubular manifold and cooled off by a Snow Performance water injection kit comprised of a Stage 2 Boost Cooler, Safe Injection System and 2.5-gallon reservoir. The centrifugal pump breathes out through a custom three-inch turbo exhaust system.
    To keep the engine running as cool as possible, AWR with the help of Ron Davis Radiators fabricated and installed the ducting, air-to-oil cooler, coolant lines, surge tank, v-mount intercooler and radiator. Andrews himself is cooled by a “Cool Suit” in-car driver cooling system.
    The Miata makes 340 rear wheel-horsepower on 16psi of boost and with 100-octane fuel. Making sure the power transfers to the wheels effectively is a Quaife custom gearbox with modified gears mated to a Flyin’ Miata flywheel and ACT clutch. In the rear, AWR prepped the differential with a Cusco 1.5-way clutch pack to keep the car pushing consistently through the turns. Slowing her down comes in the form of a Good-Win Racing big brake kit with Motul RBF600 brake fluid.
    Seated in Racetech 4009 seats and strapped in with Schroth six-point HANs-specific harness, Andrews has easy access to all of his car’s vitals, thanks to the AIM Sports Pista dash with GPS data logging. The unit is integrated through a serial connection to his Hydra Nemesis standalone ECU, another contribution by Flyin’ Miata. HB Speed tuned the engine management.
    For their efforts, man and incredible machine have a ’08 record littered with first-place finishes, most notably in the Redline Time Attack series. His accolades include:
    1st place, Modified RWD
    Redline: Time Attack! Round 1 2008, Buttonwillow Raceway Park
    Redline: Time Attack! Round 2 2008 Gateway International Raceway
    1st Place, Modified RWD & Overall Modified
    Redline: Time Attack! Round 3 2008 Miller Motorsports Park
    Redline: Time Attack! Round 4 2008 Auto Club Speedway
    Source Interlink Super Lap Battle Qualifier, Willow Springs Raceway
    Future plans for the Miata include what Andrews says will be the last major issue involving aerodynamics. He tells us that AWR is planning on developing a custom flat bottom and rear diffuser package to provide a better drag coefficient, plus a few other things he couldn’t tell us. One thing we can bank on is that Andrews’ RobiSpec Flyin’ Miata Mazda roadster will likely continue to provide beat downs in M-RWD – challengers, consider yourselves warned.
    MODIFICATION SUMMARY
    ENGINE
    Flyin’ Miata-spec 2.0L stroker BP motor
    Moldex crankshaft
    Moldex pistons
    Moldex connecting rods
    Flyin Miata headwork on 2001 BP head
    Supertech 1mm oversized intake and exhaust valves
    Flyin Miata retainers
    Flyin Miata adjustable cam gears
    Garret GT2871R turbocharger
    Boostlogic equal-length tubular manifold
    3” turbo-back exhaust system
    Walbro fuel pump
    750cc fuel injectors
    Hydra Nemesis standalone engine management
    Engine tuning by HB Speed
    AWR & Ron Davis Radiators engineered cooling systems, including ducting, coolant routing, V-mount, surge tank, radiators, air-to-oil cooler
    Cool Suit in-car driver cooling system
    ACT clutch
    Quaife custom transmission w/taller 5th gear & stronger gears
    AWR-prepped differential w/Cusco 1.5-way clutch pack
    SUSPENSION
    RobiSpec KW custom triple-adjustable race shocks w/remote canisters
    Flyin’ Miata front anti-sway bar
    V8 Roadsters tubular front sub-frame w/updated suspension pickup points
    AWR custom roll-cage
    AWR chassis gusseting
    AWR lightening
    AWR aluminum work
    BRAKES
    Good-Win Racing 4-wheel big brake kit upgrade
    WHEELS
    949 Racing 6UL 15x9”
    TIRES
    Nitto NT01 225/45R15
    EXTERIOR
    Racing Beat Type II nose
    Axis Power Racing 9-lb. carbon-fiber hood
    Axis Power Racing 9-lb. carbon-fiber hardtop
    Axis Power Racing 1.5-lb. carbon-fiber fenders
    Axis Power Racing 9.5-lb. carbon-fiber doors
    Axis Power Racing 6-lb. carbon-fiber trunk lid
    Axis Power Racing 2-lb. carbon-fiber rear bumper cover
    APR front splitter
    AWR Racing rear splitter
    Vinyl by Stickers by Jon
    INTERIOR
    Racetech 4009 seats
    Schroth 6-point HANs specific harness
    AIM Sports MXL Pista digital gauge and data logger
    93coupciv metro larev's Avatar
    canton ga
    so where do i sign up to win one of thies
    Lawrenceville, GA
    still looks like a chick would be driving it.
    Anyone who says a Miata is a gay chick car is a clueless POS.
    Flowery Branch, GA
    Miatas are gay chick cars...
    Says the Subaru owner.
    Flowery Branch, GA
    sounds like an opinion you can take to the bank eh
    Lulz. Subaru's are slow, Miatas would walk it. Where it counts.
    Flowery Branch, GA
    yes simon all subarus are slow
    Smyrna
    ☠gOOn☠ Brian*'s Avatar
    ☠Young Harris☠
    Sic!
    I love my Z m3dic8d's Avatar
    L-burn
    Miatas have a lot of respect from me, but they are feminine. You can take a feminine car and make it look less feminine, but...
    Not detracting from the fact that it handles better than 90% of the other cars out there
    Still feminine. Later, QD.
    Say What??? thegreatfnr's Avatar
    THIS
    2005 C55 AMG
    durtydubs
    WillAgreeForReps!!
    The Town of Lula
    ^^ to some extent i guess...
    Senior Member G.C's Avatar
    Forgot
    HAHAHAHAHAHAHAHA QD
    :idb:
    L-burn
    Bahaha, I just spilled protein all over my keyboard (no homo)
    One Curve At A Time
    CCR built one called Thunder. That bitch looks ready to eat a 2010 SS Camaro. I'll try to find a pic
    97 DX Civic w/ H22 FS
    One Curve At A Time
    AEM_integra
    macon
    Quote Originally Posted by FlipKing View Post
    thats cuz the 2010 ss cameros are slow my roommate had one. and i have seen that CCR one it was alright.. still there still alittle girly but i cant say anything i drive a del sol lol
    One Curve At A Time
    Quote Originally Posted by turbo_teg View Post
    they run 13.1s. Not too bad for a stock car. lol
    Stang Mod slostang's Avatar
    Southside
    forged's GTR is poppin up all over the place.
    IA Member darkshadow's Avatar
    ya the 2010's are pretty slugish : ( stock but with a little work there not to bad lots of body roll indeed. I was a worker at the MTI camero day event at little tally was a good mix of them. But i would have to say Turbo miata would eat a 2010 pretty darn easy from what i have seen and rode in.
    turbo BEGI Yata
    Senior Member DustnU's Avatar
    I'm on a boat!!
    Great post bro, thats a sick Miata for sure!! +repps
    Work in progressneed slicks!
    buford ga
    Quote Originally Posted by bdydrpdmazda View Post
    only reason to even go to the bank is to borrow more $ to fix the suby after it went off a curve trying to chase a miata in the turns:idb:
    L'ville
    i like the glass delete option, but the car looks good.
    f-ckouttahere. PRO®'s Avatar
    lmao
    JJSPEC Racing
    X2...only good looking miata i've seen....
    but still....no lsx. no care.
    -2001 Lexus IS300
    Opelika, AL
    awww....it looks so cute!!
    Daytona Beach
    This pic better describes hanging with the big boys.
    Miatas forever!
    Hell yea. I'd marry her in a second. Muscular chicks make Glides happy.
    Garage-Sixgun
    Daytona Beach
    Quote Originally Posted by Glides View Post
    Are those muscle vains around her vagine?
    Senior Member 95alty's Avatar
    Miatas forever!
    Must have been the pace car lol
    just kidding
    PIC TOO BIG
    i haz better fitment
    Dacula
    simon said it best! call it feminine all you guys want, just know when it come to racing its a more popular car than just about anything out there. sorry guys.
    ohh and if you can muscle it up to call them gay, just remember my gay car has way better fitment than your car.
    TOYOTA1515
    X-2 and gay
    SR20 Carbed Datsun B310
    Miatas forever!
    but its getting lapped in this pic.
    R Town Rida claybird's Avatar
    Coosa...Kinda Outside Rome GA
    I love miatas and I love this one its bad ass
    WANTED:
    A Girl That is DTF for a PhD
    iTrack matthewAPM's Avatar
    Otto-Flimm-Straße, Nürburg
    for deerock...step y0 game up. lol
    Matthew Brueck
    iTrack Motorsports
    www.itrackms.com
    Daytona Beach
    Quote Originally Posted by dragoncelica View Post
    X-2 and gay
    Just cause that's what you look like, picking on Miatas what help.
    TOYOTA1515
    Baaaahahhahhahaa looks who's talking
