Results 1 to 4 of 4
Thread: Brake conversion
    Banned STRteg's Avatar
    Oct 2008
    Somewhere in the USA
    Default Brake conversion
    I'm going to do a gsr disc brake conversion on my EJ What all do I need to do? I have a teggy parts car I was just going to swap everything over to the civic since I have drums in the rear the gsr is a 99 and my civic is a 95 will everything just bolt right up? knuckles,brake lines,arms,etc...?
    Quote Originally Posted by STRteg View Post
    everything from the teg will work excluding the e brake cables master cylinder and PPV. get a master and PPV from a rs da. i forgot what cables need to come need to come off.
    EJ will use a 94-01 integra rear set up
    You will use the whole rear section mounts and cable set up.. the cable de tach from the E handle and leave it connected to the Integra set up very easy takes about hour to do this.
    You don't have to use the PPV from a integra but recommended I have done these many 1,000's of time without so and they stop just fine.....If you can get the PPV then do if not screw it....
    Oct 2008
    Thanks guys
