Results 1 to 40 of 74
Thread: clean 93 civic coupe vtec!!!!! $2200 obo
    Thumbs up clean 93 civic coupe vtec!!!!! $2200 obo
    SELLING FOR A FRIEND!!!!!! cash only!!! highest offer takes it!!!! NO TRADES!!!!!!
    miles: 141k on body, 91k on 1995 d16z6 head, 140k on d15b7 block
    title: clean in hand
    VIN:2hgej2243ph523857
    chasis:
    141k original miles
    factory oem black paint
    legal window tint
    engine:
    d15b7 bottome end (140k miles)
    d16z6 vtec head (91k miles) with arp head studs
    all new gaskets, seals, ect...
    fresh d16y8 head gasket
    p28 vtec ecu. proffesionally wired vtec solenoid and oil pressure switch. it all looks factory.
    the motor has around 10.5:1 compression with the head gasket and head shaving.
    aem adjustable fuel pressure regulator
    custom fuel cut off switch, hidden to stop thieves
    95 honda civic si short geared 5 speed transmission. with oem clutch. about 3k miles on it
    hks hi-power 3" catback exhaust
    custom test-pipe
    i have all reciepts for the rebuild and all. NO LEAKS, SMOKE,OR KNOCKS!!!!!!
    suspension:
    15" REAL rota slipstreams painted black. tires have 80-90% tread left 205-55-15
    skunk2 lowering springs
    kyb adjustable struts ( you can adjust the dampening, very nice)
    skunk2 camber kit front and rear
    interior:
    si gauge cluster with tachometer
    rare grey/black cloth and leather del sol seats
    aftermarket head unit
    dual gauge pod
    now a little about the car:
    the good:
    fresh semi-rebuild on motor with around 1500 miles on it- new gaskets, seals, cam seal, piston rings, alc rod bearings, cylinders cleaned and honed. head freshened with new seals and d16y8 head gasket to up compression, head shaved .010, and arp head studs. stiff but comfortable suspension with adjustable struts ( very nice ), real slipstreams, solid mini-me swap that pulls really good. have all reciepts for rebuild. car has everything needed for power steering, Heat blows good!
    the bad:
    paint and body are not pefect, no serious dents or scratches but the paint looks a little dull it could use a wet sanding and buffing. the check engine light is on but its throwing code 14 which is the idle air control valve $40 from honda or you can take it off and clean it with brake cleaner. the transmission is an si one with short gears but does have a slight grind in 3rd. i was told the tranny was perfect when i bought it but the guy lied ( it happens ). windshield needs to be replaced but i can hook you up with a guy that will come to you and replace it for $200. the car also runs rich do to the fuel pressure regulator being fattened up. can be adjusted properly if you have a guage.
    you can call/text my buddy at 678-832-3871 jonathan for all questions. or email him at [email protected]
    [IMG]http://www.importatlanta.com/forums/picture.php?
    albumid=114&pictureid=688[/IMG]
    no turbo, pic of engine bay from old motor
    let the bidding begin!!!!! good luck with the sale jonathan. will vouch for this car
    wherever God leads geoff's Avatar
    gwinnett
    bump for my car. thanks armin! people please call/text me at 678-832-3871 jonathan. thanks
    riding for God crew member #1
    IA Domestic Alliance
    SIck em1
    Aug 2009
    G county
    bump glws
    FREE BUJU StarBwoy's Avatar
    IDK
    great price bro glws
    gwinnett
    thanx guys. so far the highest bid i got is 1500...if you can beat that then the car is yours
    gwinnett
    oh by the way its not like its a big deal but the car also has new floor mats, new head unit ( an older one ) a new mugen style shift knob ( knock off ), and i can provide a stock fuel pressure regulator so the car doesnt run so rich.
    Oct 2009
    1501?
    Aug 2009
    DOUGLASVILLE
    i will trade you a completly stock da integra with 173,000 miles it has new water pump new timing belt, oil change, tranny oil change, radiator flush, new spark plus and wires, new distrubutor, rotor buton, new thermestat, new radiator cap, new valve cover gasket, new head gasket, just did the valve adjustment as well, the car is stock and i am the 3rd owner the other owners were older people. the paint is a 8 the interior is a 9 hit me up if you are interested.
    Aug 2009
    DOUGLASVILLE
    just seen the post NO TRADES my bad i got ahead of myself.
    Has IA forgot what clean means?
    Best of luck sounds like a deal
    gwinnett
    i think for 2000 obo and a fresh motor that it fits in the category of clean. thankx guys. and to the guy who offered 1501 give me a call...i will take it
    gwinnett
    the highest bid is now $1600. whoever brings me the cash first gets the car. lmk
    gwinnett
    im getting alot of calls on this guys. this car is gonna go FAST!!! like i said come show me some cash and its yours. also, the car IS NOT TURBOED!!!
    LOL at the "Real Rota Slipstream" comment
    bump for a nice sounding car...to bad the pics dont work.
    1994 Honda Civic SI - KPOWA
    HybridRacing/ALLINFAB/KARCEPTS/K-Tuned/Bride/TopOneAERO
    gwinnett
    pics work fine. lol yeah alot of people try to pass the knock offs for the real ones
    Senior Member 9ussy's Avatar
    ac?
    I Am, A Stunt Man
    will you part the v-tec? i want some of that!
    Where Am I
    U should just take that turbo'd pic off here lol, looks like a good deal should last long...
    Certified Gearhead jojeezek's Avatar
    Jul 2009
    D16 + Turbo = The Replacement for Displacemnt
    The crack
    Quote Originally Posted by 96hatchCX View Post
    I seen what you did there............. but the car is clean though, ej ftw
    gwinnett
    car is still for sale suprisingly. someone pick up this deal. no a/c but heat blows hot
    im down right fierce hadouken's Avatar
    trade for convertible fc? + cash on your side?
    srry no trades lol my bad
    glws
    should sell fast.. i would get it if i can get my car sold... good luck.. bump fo u
    92 Hatch redneckhatch's Avatar
    White Castle
    bump....glws
    gwinnett
    ttt
    this is my old car what happened to the d16 bottom end.
    jhk
    gwinnett
    edit**** has h&r springs not skunk2. also car isnt oem black, it was painted black. i never knew i just thought it was stock black. sorry. bump
    Nice... GLWS...
    bump!
    gwinnett
    pending sale. someone beat 1800?
    gwinnett
    the buyer flaked. still up for sale. 1700 ttt
    gwinnett
    ttt
    The ShotkallA Complete's Avatar
    pm me the lowest
    Complete
    SHUT THE FUCK UP.COM bonezMTA's Avatar
    Jun 2009
    Marietta, GA
    i didn't flake. some one took $600 from my stash. know your facts before you say something negative.
    Have you heard of the guy who rolls and pulls fenders in Atlanta? YEAH, I'M THAT GUY! Hit me up! https://www.facebook.com/VipFenderRolling
    gwinnett
    well the point is that you cant buy it so its still for sale. 1700 is the lowest i will take
    dam i wish i had thy money for this lol
    gwinnett
    come on guys. $1600 and come steal this from me
    gwinnett
    ttt
    Whats next? lcortes32's Avatar
    Dec 2008
    Atlanta/SO*CAL/Nashville
    looks good gl
    93 Civic EX - Current
    95 Acura Integra GSR-Traded
    99 civic ex-Traded
    95 Civic EG DX Hatch -Traded
    96 Civic DX Coupe -Tradded
    98 Civic EX Fo' Do' -R.I.P
    93 Civic Si Hatchback (Miss you so much Buddy)
    93 Acura DA9 (R.I.P)
    97 Civic EK Coupe(tradded)
    97 Accord SE (traded)
