Thread: MOTOR MOUNT INSERTS for 96-00 civic---->any tips?
    Auto.Addicts.Racing
    Default MOTOR MOUNT INSERTS for 96-00 civic---->any tips?
    im doing this for a friend and i was wanting to know if anyone has done this yet and if is there any hints or tips that can make the job done faster....im going to be using 2 jacks....and this is for the rear motor mount that is mostly used in B and d-series only difference is the bracket u use.
    1. should i just take out the 1 bolt holding the mount to the rear bracket and just jack the motor up until i got enough clearence to slide the inserts in
    2. take out the 1 bolt holding the mount to the rear bracket and plus take out the 3 bolts holding the actual mount to the subframe, pretty much taking out the mount than re-installing the mount.
    IA's bass guy
    Nov 2009
    paulding
    well im not a expert on motors. but number 2 sounds like the better option. i dont think you want to move the block around to much.
    99 tahoe, build in progress
    Auto.Addicts.Racing
    thanks i just wanna do it faster.....someone on here had to take this rear mount out before? anyone?
    West palm beach
    I personally prefer to remove the rear bracket completely and get it out of the way...
    NO ADVERTISING
    -IA MANAGEMENT
    x2
    Jul 2009
    unbolt tranny torque mount.... 3 bolts. leave it off
    unbolt top tranny mount,,,, leave it unbolted.
    then remove the long bolt in the t bracket mount....
    jack motor up so you can reach the bushing from the drivers side working under the intake manifold.....
    bolt all 3 back together..... then do all drivers side....
    my two pennys
