Thread: LS idle prob help!!!
    Certified Gearhead 91boostdgsr's Avatar
    Jul 2009
    Griffin, GA
    Default LS idle prob help!!!
    hey guys/ gals got aquestion installed a skunk2 pro series intake manifold on my 97 ls motor in my 92 hatch everything was reinstalled as it was taken off the OEM manifold to its propper location on the new one after everything was checked and rechecked a few tim es make sure everyhtin was correctly installed after we filled the coolant back up and made sure no fule leaked anywhere the cxar was atrted and it revved high and the came down aftrer about 5 secs then its starts to idle up for about 2 secs then idle down for 2 then back up all the vaccuum line and sensors were reconnected correctly the car has 8.5 mm wires, skunk2 cam gears. aem intake, and 4-1 header help please !!!
    INSERT SIG HERE>>>____________________________
    West palm beach
    you have idle surge.
    most likely a vacuum leak, or the IACV took a dump.
    NO ADVERTISING
    -IA MANAGEMENT
    aye bro .:Stirfry:.'s Avatar
    is your iacv and fiacv clean?
    are you sure you have the right plug in the iacv?
    ATL DAsquad Member #9
    West palm beach
    Google, idol surge civic, and go from there. Tons of info on this subject and a gillion threads here as well.....
    NO ADVERTISING
    -IA MANAGEMENT
    Jul 2009
    Griffin, GA
    Quote Originally Posted by .:Stirfry:. View Post
    yea there is only one plug that fits the iacv on my harness it was working perfect bofore the manifold was insatlled
    West palm beach
    Quote Originally Posted by 91boostdgsr View Post
    there is actually a couple that will fit, even more if its obd2, double check...
    NO ADVERTISING
    -IA MANAGEMENT
    somewhere, GA
    yep ,double check everything....make sure you bled the coolant in the car properly(no air pockets), Make sure your IACV gaskets inside are sealed/seated properly, make sure your FITV ball thingy is adjusted properly, Make sure that no passages in the throttle body are blocked by anything, yadda yadda yadda
    '82 TE72 SR5 Sport Coupe
    3tc
    R A W! x Resilience's Avatar
    Atl
    Vacuum leak.
    You niggas know my pyroclastic flow, its R A W!
    - Current: E36
    Jul 2009
    Griffin, GA
    fixed the problem it was the intake manifold gasket had a tiny vaccuum leak in it but i did take yalls advice thanks for the help
