Results 1 to 13 of 13
Thread: appliance repair?
    xlr8s2K BaHumBugg's Avatar
    Jan 2003
    somewhere
    Default appliance repair?
    Hey guys didnt know where to post this but I was just wondering if getting my dryer fixed is worth it than buying a new one, the only problem is that it runs but doesnt heat up, does anybody know a local repair man also? thanks alot fellas
    www.xlr8shen.com
    (R.I.P Elliot) take care homie
    M.O.B inutero93's Avatar
    valdosta ga
    what is the year and make of it
    Where Am I
    how old is it???? I mean they aren't that much $500-800 new, or u can get them cheap on craigslist used.....
    valdosta ga
    true but dryers are pretty easy to fix i use to be a appliance tech.... most dryer parts are cheap .. and if u can work on cars u can work on dryer lol
    Quote Originally Posted by Turbodude06 View Post
    Jan 2003
    somewhere
    Quote Originally Posted by inutero93 View Post
    yea I heard they were pretty easy to fix but I dont want to messed it up even more, Im just glad its the dryer and not the washer, but its a pretty old model Kenmore, it would be very appricated if you can do something buddy and we can work something out
    www.xlr8shen.com
    valdosta ga
    well i live prolly to far away but if you have a multi meter pull the back off and u will see the heat element on the right and set your multi meter to ohms and check the wires continuity to the element and should be a small sensor right above on the element you check if there good....if they are good ....... there is two wires i think one is purple going to a while oval piece in the bottom left if no good you can wire those two together and should heat back up i will see if i can find a diagram for it or something similar .. or you can also google it ....
    Quote Originally Posted by BaHumBugg View Post
    valdosta ga
    valdosta ga
    the white oval piece im talking about is called the thermal fuse u can delete that and wire those two together if element is good
    Jan 2003
    somewhere
    Sounds good! the diagram would be helpfull, thanks man!
    www.xlr8shen.com
    Jan 2003
    somewhere
    Thank you so much man!
    www.xlr8shen.com
    Where Am I
    good info.....
    since 500-800 isnt that much for u. let me hold 700.
    Where Am I
    lol^ it isn't for how much people spend on there cars, on this site
