Thread: bad diff? drivetrain noise
    Jul 2009
    Default bad diff? drivetrain noise
    i have a ls tranny with an obx lsd..... ive had the car driving for the last 3 months since install....
    well ive never had a noise grind or anything until tonight...
    finally got the car boosted and have given it about 15 hard pulls......
    it will wheel spin to 80 mph when i let off and its a wet out.... pretty much just spinning wheels and so on. well
    i pull into my driveway and any slight turn i hear GRRRRR pause GRRRRRR pause GRRRRR pause GRRRRRR at slow speed (like barely creeping) if im straight nothing.....
    well im worried its my differential but at the same time it may be the axles???
    i have 30 weight motor oil in the case and well..... after working alllll day on it im tired and dont feel like draining some tranny fluid....
    any ideas folks?
    Why would you spin your tires to 80 on the speedo?
    Jul 2009
    srsly man? does your question have anything to do with what i asked????
    come on dude i just want some ideas about whats might be messed up or if its noisey..... ive heard quaife and obx helicals can be noisey...... it doesnt do it at say 15 mph and faster
    Quote Originally Posted by dallasb84 View Post
    If it's coming from your diff, I'd check there.
    Quote Originally Posted by 81911SC View Post
    x2
    Jul 2009
    im not sure where its coming from/.... i just took it to checkers.... and there was no noise... im thinking the beating i gave it did something??? can the diff get hot and make noise?? or how about the axles can they do that??? this is wierd
    im not a transmission person by any means. i do know ive never heard axles make the noise u described.
    Jul 2009
    update:
    main diff bearing took a shit.... lsd is ok.... just swapped trannys on my holiday vacation.... god damn
    www.jjspec.com Macon, Ga
    You can put bearings in, you dont have to replace the whole trans.
    update:
    so you ended up making it up to virginia ok? how was the ride up? did you get your dump tube done yet?
    Jul 2009
    yeah i barely made it up..... ha ha
    once i got there i bought another ls 5 speed and swapped it in..... im going to tear apart my other tranny and fix it.... dump tubes not done but i did get a check engine light.......
    i havent tried to pull codes off it yet to see what it is..... but the motor ran great.
    pull the code and let me know asap.
