Thread: ls swap clutch problem
    Aug 2009
    Default ls swap clutch problem
    i cant seem to bleed my clutch i got a ls in a ej i thought it was the slave cylinder so i bought a new one put it on, fluid runs through it, i've bled it but the clutch pedal still gets no pressure at all anyone might know what the problem might b?
    also when i pump the clutch pedal the slave cylinder/throwout bearing does not pump
    Quote Originally Posted by honda001 View Post
    either there is a lot of air in the lines. u are doing it wrong or u got a failing component.
    i think your bleeding it wrong..
    West palm beach
    x2
    NO ADVERTISING
    -IA MANAGEMENT
    these are usually easy to bleed, the accord/prelude can be a bitch sometimes but the civic/integra usually easy... You need to make sure that the clutch master cylinder isn't the problem, giving you the benefit of the doubt that you are doing it correctly.
    vtakkk hondaxpurt's Avatar
    TALKING ROCK, GA
    the key is to tighten the bleeder BEFORE you release the pedal...just a thought.
    98 Acura Integra LS-DD
    ??????????????????-project
