Results 1 to 1 of 1
Thread: Lots of E36 stuff: pics inside
    aka....RAFA RJ's325ITS's Avatar
    Stockbridge, Ga.
    Default Lots of E36 stuff: pics inside
    I have 1 set of S52 valve springs for sale (24 valve springs total), I'm upgrading so I have no need for these. This set is a good upgrade for M5x base engines.
    $90 shipped
    This housing came on my S52, it's in good condition and worked pretty well when I took it out of my engine.
    I was using this housing in my turbo car for the:
    Turbo feed line
    Oil pressure gauge sender unit.
    The housing has a total of 4 ports, you can miss match them to your taste, or used them in different multiple setups, such as:
    Vanos, oil switch, oil pressure & oil temperature
    Vanos, turbo feed line, oil pressure & oil temperature
    Or even use a mechanical pressure gauge.
    I've been told that ports #1 & #2 could be use for an oil cooler, with the help on an external thermostat. This housing does not have the internal thermostat, it didn't come with it.
    Asking $150 shipped w/in the US.
    here are some pics,
    I have a M50 block for sale, has 100-125K miles on it. You can use this block for:
    M50 straight swap
    M52 w/a OBD1-Conv.
    S50 bore it, & then bolt it on
    S52 OBD1-Conv. + boring it.
    Here it is a list of what you will get:
    1 M50 block
    1 M50 crankshaft
    6 M50 rods
    6 M50 pistons w/ rings
    7 crankshaft main caps w/ bearings
    $150 + shipping
    thanks
    PS: Im willing to part it out for the right price
    Good upgrade for those that have the OBD2 manifold, also must have for turbo since the OBD2 leak under hi-boost.
    Looking to get $90 shipped w/in the U.S.
    Thanks
    Here are some pics:
    I also have lots of other parts, such as M50 cams, cam gears, timing chains, rods, pistons, A/C brackets, oil filter housings, valve covers, engine covers, chain guides, motor bracket etc....
    So sent me a request via PM for whatever part you are looking, and I will reply asap.
    Thanks a lot,
    Rafa
    TRM Stage 2 │TRM Coilovers │ TRM Pistons │ TRM Blowthrough Tuning │ TRM MAF & Injectors │ Watch My Crazy Videos
