Results 1 to 13 of 13
Thread: 01 civic lx headlamp does not work
    E38 740i M fininfarina's Avatar
    Default 01 civic lx headlamp does not work
    Low beam does not work, but works on high beam
    First, I thought both of bulbs are blown but they are fine
    I have checked fuse. everything looks fine
    whats the problem??
    * Where I can get cheapest battery??
    JDM TYTE AnthonyF's Avatar
    Quote Originally Posted by fininfarina View Post
    whats the problem??
    Why do you need a battery? Did you replace the bulbs?
    -Ant.
    The Carbon Fibered R6
    West palm beach
    bulb is fucked....
    NO ADVERTISING
    -IA MANAGEMENT
    I replaced the bulbs already
    I need battery replacement because everytime I started engine, start motor is really weak, I had to have jump this morning
    Quote Originally Posted by AnthonyF View Post
    -Ant.
    ^get your battery checked first, it could be your alternator
    somewhere, GA
    If you replaced your bulb recently and its still dong this then there is a slight possibiilty the new bulb is bad. Did you touch the actual glass on the bulb when you replaced it? If the high beam works then the HL socket is getting power.
    Test the battery and the alternator...Its free they are easy to remove/replace
    '82 TE72 SR5 Sport Coupe
    3tc
    vtakkk hondaxpurt's Avatar
    TALKING ROCK, GA
    i hate to state the obvious, but its the right bulb right? could also be a low beam HL relay...
    98 Acura Integra LS-DD
    ??????????????????-project
    bad wires, switch, relay
    Yes I got the right size new one
    Quote Originally Posted by hondaxpurt View Post
    Now Iam suspending that the wires are no good
    I have found 1 100w bulb in the glove box and its from previous owner.
    So how do I check the wires?? or change?
    dmm set to ohms
    Sorry I do not understand.. Can you help me with that again??
    dmm set to ohms
    digital mutli meter set it for ohms so to check for continuity in your wires.
