I have a Brand New never installed Lakewood bellhousing in great condition only a few scratches from storage. As the lakewood site states:
SAFETY BELLHOUSING-CHRYSLER / Dodge
Dedicated applications assure a direct fit for all popular passenger cars
Complete with safety block plate and grade 8 hardware
The stock cast aluminum bellhousing is adequate for OEM applications, but mounted behind a high horsepower - high RPM engine, the cast aluminum bellhousing could become deadly shrapnel in the event of a clutch/flywheel explosion. Hydroformed from premium quality steel plate to ensure uniform thickness throughout for superior strength. Stress relieved after forming results in a stronger, safer bellhousing. Mig-welded threaded inserts for transmission mounting bolts, clutch pivot ball and clutch linkage brackets where required. Precision machined to assure proper bolt hole and center bore alignment. Blanchard ground mounting surfaces for precise parallel alignment of engine and transmission. Dedicated applications assure a direct fit for all popular passenger cars. Approved by all major racing sanctioning bodies and meet SFI 6.1 specifications. Complete with safety block plate and grade 8 hardware. Fits Chrysler 1964-83 with 273-318-340-360 V-8. Notes: Fits 130-tooth flywheel. Transmission: New Process 3 & 4 speed. Bore Diameter 4.807. Depth w/Block Plate 7.50. Fork Opening 3.12 x 4.00.
Model Number: 15320
Some websites say it can fit up to a year 2000 car so it very well could be for 1964-2000 mopar dodge and chrysler
Im asking 350 obo, Price is definitely negotiable
Call or text Justin 678-982-4093
