Results 1 to 24 of 24
Thread: My car wont turn on.
    Bad Luck kID FAM0U5's Avatar
    Dec 2008
    Default My car wont turn on.
    Hey guys as some of you know Ive been wanting to install the ARP headstuds... well, it happen I got them installed but now I ran into a different problem I cant get eletric current threw the distributer cap plug thingy. [dont know what it is called but it has a male and female connection.] It rungs from the cap and over the cam gears and under the intake manifold. I have tested the MSD thing that battleground installed and that gets current however my spark plugs wont light up. The timing is right everything is pluged right and IDK what else it could be.
    Jul 2009
    sounds like a sensor is unpluged like a cps
    somewhere, GA
    check all grounds
    '82 TE72 SR5 Sport Coupe
    3tc
    aye bro .:Stirfry:.'s Avatar
    x2
    ATL DAsquad Member #9
    year make model
    year make model
    wild guess toyota supra
    Quote Originally Posted by ASE*Tech View Post
    warning: IA leave nothing to be assumed.
    West palm beach
    you two crack me up....
    NO ADVERTISING
    -IA MANAGEMENT
    West palm beach
    MY car wont turn on....
    NO ADVERTISING
    -IA MANAGEMENT
    turn the key?
    Quote Originally Posted by Purple Power View Post
    turn the key?
    see start simple build your way up.
    Quote Originally Posted by FAM0U5 View Post
    My question is how did you test the MSD ignition? Did you stick your tongue to it? That always works for me...it's just like a 9v battery.
    Dec 2008
    Quote Originally Posted by speedminded View Post
    I used a tool that is used to check such things I dont know what's its called but you have to ground the tool that is linked up a device that lights up when you touch the power source.
    Dec 2008
    Quote Originally Posted by dallasb84 View Post
    thank you Ill check that..
    Dec 2008
    year make model
    toyota supra 95
    Dec 2008
    turn the key?
    Not to be rude but this IS serious question not a random thread posted in the WL, so take your smartass remark with ya ok? ok good..
    that would be a test light to fully test u would need a dmm.
    what work have u done lately.
    Test lights are generally for 12 volt power sources...are you saying 12 volts is coming out of your MSD ignition?
    GWINNETT IS GREAT!
    Dec 2008
    I guess so..
    Dec 2008
    just the headstuds..
    In the land of the slow cars
    When you took the head off your car to install the studs, did you pull any sensors off that may not have gotten re-connected? Check everything in and around your head (sensor and wire-wise). Are you sure your distributor wire is good? And what about the button inside the distributor?
    Dec 2008
    Quote Originally Posted by stillaneon View Post
    ok ill do it right now.
    Sounds like something didn't get connected, what did you find after double checking?
